Results 1 to 14 of 14
Thread: CEM removal P2R
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    CEM removal P2R
    Hi all.
    Has anyone/does anyone know how easy/difficult it is to remove the CEM on a 2004 V70R?
    I know its location but i need to know the extent of the work involved.
    Cheers!
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    You got problems with the R Lee? Sorry I have no idea.
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,487
    Here's a brief description with a few pics:
    http://www.matthewsvolvosite.com/for...ic.php?p=51613
    Seems fairly straight forward......hth
    Jul 2008
    126
    It's under the scuttle panel on the Facelifts, not sure if that also means 04 R's or not.
  5. #5
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    the scuttle boxes on p2's earlier than 2004 can all suffer from water ingress.
  6. #6
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by partsforvolvos.com View Post
    Precisely why i think my CEM is being damaged by water and causing me intermittent DRL's faults. Mainly with the FLEX*** settings and the LED on the switch.
    Volvo know there is a fault, they've had it in twice, they just don't know why!!
  7. #7
    Jul 2008
    126
    The problem is only on a certain number of facelift cars. Your dealer should have checked you chassis already.
    The pre facelift cems were under the dash drivers side AFAIK. Volvo stopped the facelift issue by fitting a rubber grommet in the cem plenum. I guess most cars have had that fix already.
    Anyway mines an early facelift 54 plate and wasn't affected according to Volvo.
    Given your issues it'd be wise to check the connections on the cem for corrosion. On the facelift one there is four different multiplugs for comms canbus etc. And a dual 30 amp feed into it.
    It should be pretty easy to tell by pulling the plugs and checking both sides and the earth etc.
    The CEM is basically the cars server and termination point for networking. A faulty one could definitely be the cause.
    I've got a facelift one here if you need pics
    Quote Originally Posted by LeeT5 View Post
  8. #8
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Thanks Dreamer. How easy is it to get to the CEM without removal?
    ie...so i can remove plugs and check for corrosion without physically removing the cem.
  9. #9
    Jul 2008
    126
    I've no idea mate, I have one I've been playing with on a bench from a facelift, never removed or fitted one.
  10. #10
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Have a look on Vida that will tell you under the how to repair bit.
  11. #11
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Lee just found this video
    Volvo Central Electronic Module CEM Removal Proce…:
  12. The Following User Says Thank You to Harvey For This Useful Post:
    LeeT5 (Wednesday 31st December 2014)
  13. #12
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Wow, only a year late.
  14. #13
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Better late than never...
  15. #14
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    I never got round to taking my CEM out last year cod its s big job and the car will be off the road. This video will come in handy in the spring. Thanks Harvey mate ��
