Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jan 2013
    EAST KENT
    0
    Front Control Arm Front Bushes 2003 S60 D5 Replacing
    Just had my S60 D5 serviced by Volvo and they recommended replacing the front control arm bushes , is this an easy job and what to do did do a search but could not find. Car has only done 61000 miles from new.Peter
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    MRP has done these i believe
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    powerflexing wishbones
    just be sure to remove the hub bolt before you start and make sure the drive shaft doesn't come out of the inner cv.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
    All work and no play makes
    Jack a dull boy
    Jul 2012
    North Yorkshire
    88
    Unusual for a main dealer to advise replacing just the bushes as the "official" Volvo method is to replace the entire wishbone.
    Approx £150 per side when I had mine replaced at an indy, About £350 ish all in if I remember correctly usually more at a main dealer.
    Rebushing is definitely the cheapest option if you have the skill and tools, which I don`t!
    It would probably be quicker to list the things MRP`s not done
  5. The Following User Says Thank You to Fubar1977 For This Useful Post:
    M-R-P (Tuesday 1st October 2013)
  6. #5
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Volvo workshops should have a porta power type tool and dies to change the bush on the car but why would they when the can sell you a new set of arms.
  7. #6
    Jul 2011
    Poole, Dorset
    6,548
    clutch
    timing belt
    turbo swap
    glass replacement
    remapping
    310.2bhp / 333ft/lb
    SOLD
  8. The Following User Says Thank You to M-R-P For This Useful Post:
    Fubar1977 (Tuesday 1st October 2013)
  9. #7
    Kawasaki T5. Built by a Swede,
    Driven by a turnip!
    T5RatherAmusin's Avatar
    May 2013
    SW Wales
    303
    Knock the shaft out the hub. And hold it out the way with a bungy if u want to keep out the way from any incident s of it coming out and making a mess lol
    The rest is comon sense really. Theres a vid that may be a lil helpful on youtubes...
    But its just s matter of bolts really.
  10. #8
    Jack a dull boy
    Jul 2012
    North Yorkshire
    88
    clutch
    timing belt
    turbo swap
    glass replacement
    remapping
    (Yet)
  11. The Following User Says Thank You to Fubar1977 For This Useful Post:
  12. #9
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    Quote Originally Posted by Fubar1977 View Post
    we used to replace only bushes all the time.
    the price saving on buying just the bushes instead of a whole arm, is better than the extra .3 labour allowance you get for pressing the bushes after it is removed.
    + on this fitment there is no built in balljoint, so no real reason anything would be wrong with the actual frame.
    indy's would prefer a whole arm for convienence, if they did not have the correct press tools which a dealer has no choice in buying as they are a required tool.
  13. The Following User Says Thank You to partsforvolvos.com For This Useful Post:
    Fubar1977 (Wednesday 2nd October 2013)
  14. #10
    Jan 2013
    EAST KENT
    0
    Are the Meyle bushes good only donot want to use power flex ones as I understand they make ride hard. Peter
  15. #11
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by welderone View Post
    There's no real added hardness of the ride. There's a tiny amount of extra road noise but the big advantage is the reduction in steering slack (woolyness) and the extra feel and precision in the steering.
    Well worth doing, and I've done a few.
    310.2bhp / 333ft/lb
    SOLD
  16. #12
    Jan 2013
    EAST KENT
    0
    Ok cheers waiting to see if this can be done under warranty , only the front back ones were done when I first got the car on warranty
  17. #13
    Jack a dull boy
    Jul 2012
    North Yorkshire
    88
    Quote Originally Posted by partsforvolvos.com View Post
    I stand corrected in that case.
    I was quoted for the full arm by a main dealer not too far from me as "we can`t just change the bushes, the whole arm is replaced".
    Probably just trying it on a bit then, I just got the indy to price me for new arms.
    I now realise it`s not an especially hard job to rebush and would have gone down that route if I`d been thinking more about it...
    Still wouldn`t try it myself at home though...I stick to the (very) basics but I like learning how to do things where I safely can.
  18. #14
    Jul 2011
    Poole, Dorset
    6,548
    We all have to start somewhere mate. I wouldn't have contemplated dismantling a Volvo 4 years ago but I'll happily rip the old boat apart to fit new mods these days.
    There are, of course, some individuals that simply shouldn't be allowed to hold tools (I'm looking at you miss daisy) but it does the mind good to challenge yourself from time to time.
    310.2bhp / 333ft/lb
    SOLD
  19. The Following 3 Users Say Thank You to M-R-P For This Useful Post:
    Fubar1977 (Thursday 3rd October 2013),partsforvolvos.com (Thursday 3rd October 2013),V70 Graham (Thursday 3rd October 2013)
  20. #15
    Trader
    Jun 2012
    270
    no problem, you're welcome.
  21. The Following 2 Users Say Thank You to partsforvolvos.com For This Useful Post:
    Fubar1977 (Thursday 3rd October 2013),M-R-P (Thursday 3rd October 2013)
  22. #16
    Jul 2011
    Poole, Dorset
    6,548
    Lol - it's your fault I learned how to remove wishbones in 10 minutes, The front bushes can be done with the wishbone on the car. Although, if I did it again, knowing what I know now, I'd just pull the wishbone off and do both bushes in one hit. (obviously, using bushes that don't fail in 1800 miles )
    310.2bhp / 333ft/lb
    SOLD
  23. The Following User Says Thank You to M-R-P For This Useful Post:
  24. #17
    Trader
    Jun 2012
    270
    ooh that was low , lol.
    now you are a fully appointed test pilot though
  25. #18
    Jul 2011
    Poole, Dorset
    6,548
    Thanks - I think
    I wanna test some shiny stuff next time tho
    310.2bhp / 333ft/lb
    SOLD
  26. #19
    Jul 2011
    Poole, Dorset
    6,548
    I wonder if Graham will let me "run in" his new shiny thingy, ready for tomorrow...?
    310.2bhp / 333ft/lb
    SOLD
  27. #20
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Course he will
