Page 3 of 11 FirstFirst 12345 ... LastLast
Results 41 to 60 of 205
  1. #41
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    You will have to use your own ecu for mapping the 70'r they are the only cars in the 70 range with one lambda all the others have 2.
  2. #42
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by Jamest5r View Post
    eh? thought they had two - mine has so I would guess that the manual verson has a front and rear 02 sensor...?
  3. #43
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Quote Originally Posted by jamesy12345 View Post
    Sorry mate what car do you have?
  4. #44
    Iraq Lobster
    May 2013
    4,606
    I meant my S70 T5 auto
  5. #45
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Yours will have 2 the r's only have a pre cat lambda
  6. The Following 2 Users Say Thank You to Jamest5r For This Useful Post:
    jamesy12345 (Monday 30th September 2013),T5frankie (Monday 30th September 2013)
  7. #46
    Iraq Lobster
    May 2013
    4,606
    oh cheers Jim, I didn't realise...more new knowledge gained, busy day today!
  8. The Following User Says Thank You to jamesy12345 For This Useful Post:
    Jamest5r (Monday 30th September 2013)
  9. #47
    Here today gone tomorrow
    Nov 2010
    Essex
    567
    The 854 R saloon spolier has got to be one the best mods you could do to the looks on an s70 should of come from Volvo with one fitted as standard!! My R has 2 lambda sensors, when I changed to a larger downpipe which only came with one sensor hole I had the ECU sent away to have it deleted off, so the car now runs with one.
  10. #48
    T5 powered and retro
    munster732's Avatar
    Apr 2012
    Barnsley,South Yorkshire
    171
    Quote Originally Posted by Jim S70R View Post
    Very very nice car that you've got yourself, again as said in above post nice to see another saffy being loved!! I'll have to take the dust off mine and we'll all have arrange a photo shot at some point.
    Thanks Jim, means a lot coming from you. I would jump at the chance to get together for a photo shoot, although I would feel very, very inferior as mine has a long way to go to get it anywhere near the standard of yours.
  11. The Following User Says Thank You to munster732 For This Useful Post:
    Jim S70R (Monday 30th September 2013)
  12. #49
    munster732's Avatar
    Apr 2012
    171
    It was pointed out by big Petey that I only had one lambda sensor when we were under it on sunday
  13. #50
    Nov 2010
    Essex
    567
    Quote Originally Posted by munster732 View Post
    Like what the guys where saying earlier on it takes time to sort it all out to get as nice as you want it, you've certainly got yourself a good one as a starting platform so your already over half way there. I've spent 6 years on mine and I'm still not finished with it, it's got plenty of things left to do trust me.
  14. #51
    munster732's Avatar
    Apr 2012
    171
    Quick update on the munter, went out last night after leaving the car on the drive for about 2 hours. My nice new pink anti freeze had made a break for freedom and was legging it down my drive :-(
    It was very dark but with the aid of a torch I saw the expansion tank was almost empty and the drip was somewhere in the vicinity of the middle of the undertray. Whipped undertray off and could see that it was coming from somewhere on the off side radiator end cap. Bloody car is so low I couldn't get my trolley jack under and as it was dark and I was getting scared I went in.
    After work today I put the car onto axle stands and topped the expansion tank up. Ran the car for 15 mins until the car had cut the fan in a few times....no leaks at all??? Turned it off and put some cardboard under the car and within 5 mins a small drop was forming at the bottom of the radiator end cap. Thinking of putting some Rad seal through it or such like tomorrow as it only seems a slight leak. If that fails it will get a new rad fitted.
    Welcome to S70R ownership, she's already spat the dummy out lol
  15. #52
    Nov 2010
    Essex
    567
    Bad times but see it as only a minor set back!! To save any future problems might be worth going straight for a replacement rad.
  16. #53
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    I have a spare 4.4 for a single lamda if you want to keep your standard one, was going to flog it to Hamish but if you want let me know
  17. #54
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    That's weird???
  18. #55
    Nov 2010
    Essex
    567
    That's weird???
    Maybe they changed the design over the different year models perhaps, Early and late S70R's
  19. #56
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    My C70 only has one lambda.
  20. #57
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Some clever dick will tell us sooner or later
  21. #58
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Don't put rad weld in buy a new rad u tight ass lol
  22. The Following User Says Thank You to t5 pete For This Useful Post:
  23. #59
    munster732's Avatar
    Apr 2012
    171
    Quote Originally Posted by t5 pete View Post
    Already ordered big boy, the path from munter to minter is getting longer lol
  24. #60
    munster732's Avatar
    Apr 2012
    171
    Pm me a price Jimbo, but be nice cos Ive just bought a radiator and will have to feed the big lad when we fit it...expensive times :-)
