Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    Air con smells of P15S
    Hi,
    as title. Had it on for an hour. Turned car off when got to work. Got back in 7 hours later when it was cool outside and could smell it coming through vents (A/C off)
    I know this can be common so not too worried. Obviously don't want to have car smelling of wee!
    I am sure there is an A/C expert on the forum somewhere, but I can't remember who, so if you have got your ears on, what do I do??
    Thought I would get a bomb and recirc it. Where is recirc intake on 2005 V70?
    Cheers guys
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,487
    Remove the pollen filter from behind glovebox before deploying the 'whiff' bomb. May as well refit a new one whilst you're in there.
    You could perhaps remove the plastic scuttle panel under the wiper arms and give all the channels below a good disinfecting.
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    By reading a few threads most of us just look for a service centre to have it looked at professionally. Cheapest I've seen it was £29.
    Current Garage:
    *Data Sept 2013
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Mr Evans is the man you're after.
    The intake is in the passenger footwell mate. First, check the pollen filter and change if needed, they can get damp if the AC is on for a while and stink when the ac is off.
    It's also worth running the fans for a few minutes with the AC off to help clear the condensation after it's been on for a while.
    The bomb things do work too - I used one a while ago and in the instructions, they pictured it being used in a S60
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  5. The Following User Says Thank You to M-R-P For This Useful Post:
    silverhorse (Wednesday 4th September 2013)
  6. #5
    Jul 2011
    Poole, Dorset
    6,548
    Too late
    310.2bhp / 333ft/lb
    SOLD
  7. #6
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Stephen Evans is the resident air con expert.....oh hold on
  8. #7
    Swollen Member
    May 2006
    1,487
    If you find a garage or bodyshop who has a Wurth account, ask them to get order some Wurth A/C Disinfectant Spray:
    http://www.wurth.co.uk/product/aircondisinfectantspray
    Awesome stuff just to squirt down your vents once or twice a year....one tin will treat 30-40 cars. Potent stuff !!
    060195.pdf
  9. The Following User Says Thank You to stephenevans99 For This Useful Post:
  10. #8
    Give me a high 6!!!
    Oct 2012
    221
    Quote Originally Posted by JUDGENINJA View Post
    That's fair enough I spose
  11. #9
    Swollen Member
    May 2006
    1,487
    Quote Originally Posted by V70 Graham View Post
    By far from expert status....lol I just like AC and earn a few quid in the Summer. But I'm flattered nonetheless. pmsl
  12. #10
    Give me a high 6!!!
    Oct 2012
    221
    Quote Originally Posted by stephenevans99 View Post
    I thought it was you, but did not want to put your name up in case I was wrong!!
    That Wurth stuff does not list the price. I assume it is not £1.99 a tin?
    Cheers for help guys. I will get on the case.
  13. #11
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    hello paul, if it is as bad as you say, it might need some disinfectant spraying directly on the the evaporator core as this is where the bacteria that cause the smell actually live. if u use the bomb and it does not fully sure it, this will be necessary. i have seen them sometimes where loads of green **** comes off if it is really bad so you want some paper floor mats on the carpet to protect it !
    also, it might be your a/c drain is blocked and the water is pooling inside the heater box- do you see any water dropping under the bulkhead area onto the floor, having used the a/c for a journey?
    jamie
  14. The Following User Says Thank You to partsforvolvos.com For This Useful Post:
  15. #12
    Give me a high 6!!!
    Oct 2012
    221
    Hi Jamie,
    to be honest I did not check underneath for evap dripping. I think I may just do as JUDGENINJA says and get a service for £30 if I can. It's the first time it has happened, but also I have not used the A/C for ages as it makes the wife sneeze!!!???!!! Dumbarse
  16. #13
    Trader
    Jun 2012
    270
    if she is sneezing, that could be just dust in the section of the pipework near the a/c that hasnt been moved by airflow.
    there's always the bus..... but i'll let u suggest that one.
  17. #14
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    I sell what they call in the trade a Aircon bomb. you put the a/c on recirc shut the doors and windows and let the ac bomb off inside it will spray a disinfectant out for about 10 mins and it will get drawn through ac system and kill all the bacteria works really well.
  18. #15
    Give me a high 6!!!
    Oct 2012
    221
    Quote Originally Posted by partsforvolvos.com View Post
    LOL. No, she is just a dumbarse. We can walk into tesco with their aircon on and she sneezes. I did suggest a bus instead of buying her C70 T5. Much cheaper. Didn't go down too well!!
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
  19. #16
    Give me a high 6!!!
    Oct 2012
    221
    Quote Originally Posted by merc85 View Post
    Seen them on internet. Might be worth a try. they are quite cheap and if they work, happy days.
  20. The Following User Says Thank You to silverhorse For This Useful Post:
    merc85 (Wednesday 4th September 2013)
  21. #17
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Or if your are feeling really rich,book in to volvo to get the after blow function switched on this runs the cabin fan for about 5 minutes ,1 hour after you lock the car up which drys the evaporator up.
  22. #18
    Give me a high 6!!!
    Oct 2012
    221
    Oooh, that sounds interesting. Is that a software download? But, I'm not feeling rich though!
  23. #19
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
  24. The Following User Says Thank You to Harvey For This Useful Post:
    silverhorse (Thursday 5th September 2013)
  25. #20
    Junior Member
    Jul 2013
    Gloucester
    6
    bacteria in the system mate, also your car should have an after blower thingy that kicks in after so long to dry out.
