Hi all
2002 S60 D5 140000mls.
Just had the return of Limp Mode above 2500rpm, especially when engine is cold.
Was occasional but now happens pretty much every day, especially when accelerating steadily up to 3500rpm.
Going above 3000rpm when cold will pretty much always do it.
Will also sometimes do it with engine up to temp.
No warnings on DIM and no warning lights on dashboard.
Cars had a new intercooler, MAF, Fuel filter, airbox and most of the turbo hoses replaced in the last 6 months.
Nothing obviously loose, perished or damaged under the bonnet.
As a process of elimination I have just disconnected and blanked off the vacuum engine mounts and, so far, it seems to have stopped the limp mode issue.
Took it out this morning, stone cold, and TRIED to get it to limp and wouldn't, same story later with engine up to temp, need to do it over a few days to be sure.
Long story short, I am skint as far as spending more money on the car goes for at least the next 2 months so, what I'm asking is:
How long can I safely leave the mounts disconnected for?
I'd like to leave them off for a good few days to confirm my suspicions that the fault is with the mounts or associated pipework or possibly the switch on the airbox.
It could well be a few weeks before I'm able to get it in for proper diagnostics as the only place near to me would be a main dealer it won't be cheap and my concern is that leaving then unhooked for weeks might cause other issues.
Any advice appreciated but it WILL be weeks before it can go in for any more work or further professional diagnostics.
Thanks guys.
