Page 7 of 18 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 349
  1. #121
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by MoleT5-R View Post
    thanks Paul, that explains why there wasn't one on the 2.0l v70 as it doesn't have cruise control
    It was a surprise to me how this thing worked - I got a shock when the pedal started moving on its own, having been used to either no cruise control or electronic stuff previously...
    http://www.volvoclub.org.uk/tech/ser...trolSystem.pdf
    http://volvospeed.com/vs_forum/topic...ntrol-diagram/
    I think your photo in the post above was of this blue thing here.....green thing is the vacuum servo that moves the pedal
  2. The Following User Says Thank You to jamesy12345 For This Useful Post:
    MoleT-5R (Saturday 22nd March 2014)
  3. #122
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by jamesy12345 View Post
    That all makes sense and as you say it's the blue item in the drawing, so I'd better leave it there as I use cruise in speed limits to save on getting points...lol
  4. #123
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Time for a small update on the T-5R and whats happened in the last few months
    The engine was dropped out on its subframe for a transmission swap and new up-rated clutch to be fitted, a fairly painless job, of which I'm getting well practiced at, for reasons most of you know.
    Flywheel looks to be in good condition for 270,000 miles and is now fitted with an R clutch plate and up-rated Sach's cover which certainly is up to the job, as for pedal pressure, I'm going to have one leg bigger than the other, its heavy but tolerable
    The standard clutch on the left and the new one on the right
    Clutch fitted
    Timing belt and new shorter auxiliary belts fitted and aircon pump removed (space for a supercharger someone might say)
    Amazed by how clean the 3" throttle body was after 9-10 months of daily use and the Jap manifold is still looking crack free
    The same couldn't be said for the turbo, which had a nasty looking crack in the exhaust housing, across the waste gate area, so it was changed for another 15g, which was most kindly donated by Colin from his T-10K's donor car (Thanks again mate)
    subframe swap and installation of some "Sponge" inserts to stiffen things up, polybushes to be added at a later date to the lower arms and arb bushes will be up-rated at the same time
    and the cheapo flea bay disc's are still in good condition after 18 months or more
  5. The Following User Says Thank You to MoleT-5R For This Useful Post:
    Jamest5r (Saturday 7th June 2014)
  6. #124
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Yesterdays tidy up session pinched one of WD's ideas and hid the H.I.D. ballast's in the ecu box and the passenger ones behind the battery
    also went about sorting out the loose bracket in front of the power steering pump, searched high and low in the garage for the long bolt and sleeve, only to come to the conclusion that when the previous owner had the engine changed, some 170,000 miles ago, that the garage never re-fitted the part, as it's not in the pic of when the engine came out
  7. #125
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    New mod just finished a couple of minutes ago, to compliment Pete's old grill is it's new v70 bonnet catch, no longer any need for the little rod poking through the mesh..
    think a wash and a good polish should be next if the weather picks up a bit
  8. The Following 6 Users Say Thank You to MoleT-5R For This Useful Post:
    AndysR (Sunday 8th June 2014),claymore (Saturday 7th June 2014),Jamest5r (Saturday 7th June 2014),JT (Monday 23rd June 2014),Nealevo (Sunday 8th June 2014),t5 pete (Sunday 8th June 2014)
  9. #126
    Jul 2008
    2,869
    Nice work, love the 70 series bonnet release, was it tricky to fit? How did you fit it and was there much to modify to get it to fit?
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  10. #127
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    [QUOTE=AndysR;717493]Nice work, love the 70 series bonnet release, was it tricky to fit? How did you fit it and was there much to modify to get it to fit?[/QUOTE
    Yes mate, the V70 bonnet pull is much nicer than the 850 one, but on the v70, the slam panel has a scoop, low down to accommodate your fingers when you pull it, so things are a little tighter on the 850, but it seems to fit ok and I can get my fingers around it ok to release it. All that was required was a suitable bit of rod to be bent to shape as the 850 rod length needs to be longer than the v70's. The catch just clip's in on the V70, so a couple of slots need the be cut for the bottom of the catch to pivot in to, the top just then clip over, the position on mine wasn't perfect so I added a clip to the bonnet internal edge for the clip to catch on, but other than that it is pretty much straight forward, I'll try and get some pic's of the slots it clips into in the next few day when I'm off work
  11. The Following 2 Users Say Thank You to MoleT-5R For This Useful Post:
    AndysR (Tuesday 24th June 2014),smithy (Tuesday 10th June 2014)
  12. #128
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Will I think it's time to open up the 10v gearbox and see what the damage is...... and whilst I'm in there thought I'd improve the traction a tad...
    DSC_0062 by moleadrian, on Flickr
    DSC_0064 by moleadrian, on Flickr
    DSC_0065 by moleadrian, on Flickr
    And yes I will put oil in it this time.....before someone kindly reminds me.....lol
  13. The Following 2 Users Say Thank You to MoleT-5R For This Useful Post:
    AndysR (Tuesday 24th June 2014),WOODY T5 (Monday 23rd June 2014)
  14. #129
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Ohh look, you've found my diff
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  15. #130
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Ooooo i like the quaife, welcome to the club, just make sure you remind Jim at every opportunity lol
    and don't forget the oil ��
  16. The Following User Says Thank You to Nealevo For This Useful Post:
  17. #131
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Bah you can go right off some people
  18. The Following User Says Thank You to Jamest5r For This Useful Post:
    MoleT-5R (Monday 23rd June 2014)
  19. #132
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Quote Originally Posted by Nealevo View Post
    Sod off you.....and where's the new brakes
  20. The Following User Says Thank You to Jamest5r For This Useful Post:
  21. #133
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    A bit to do yet, I think the box is going to be full of filings,just going buy what I saw on the reversing switch selector, will be in need of a thorough clean out and pressure wash to start and see where we go from there, got to get it all done and fitted for the next Avon meet.......hopefully
  22. #134
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I also have a secret weapon for the next Avon meet
    PIC][/SIGPIC]
  23. The Following User Says Thank You to claymore For This Useful Post:
    smithy (Monday 23rd June 2014)
  24. #135
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by claymore View Post
    Interesting......an even bigger spring.......??
  25. #136
    Moderator
    NOS
    WOODY T5's Avatar
    Sep 2005
    hull
    2,573
    Quote Originally Posted by MoleT-5R View Post
    that should do the job mate very nice
    "WOODY T5 fastest volvo 850 since 2011/12/13/14 @ avon and york 13.3 112mph
    854 t5 19t gripper mte bc loads more 311.6 whp 373 foot pound 342 @ clucth
    toy cbr954
  26. The Following User Says Thank You to WOODY T5 For This Useful Post:
  27. #137
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    yet you still persist with a rubbish 15g adrian, that queerf aint gonna get you any quicker lol
  28. #138
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by WOODY T5 View Post
    I'm hoping that the combination of the drop in gearing and the extra traction should help my times improve, without having to find more power yet.....next year may see engine mods but we'll have to wait and see what money is about for those, I'll try to quietly tuck a bit away regularly and build the funds up hopefully.
  29. #139
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by T5frankie View Post
    we'll see what happens...my 15g has done well so far and there's a bit more to be had yet...
  30. #140
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Nice lookingf bit of kit mate, hopefully one of those will adorn my gearbox one day. Don't listen to Frankie, stick with the 15g, it's the only way I'll beat you once my 18t is fitted.
  31. The Following User Says Thank You to stribo For This Useful Post:
There are currently 6 users browsing this thread. (0 members and 6 guests)
