Nice progress there Adrian, intake setup looks smart
MoleT-5R (Thursday 12th September 2013)
Kept this a bit hush hush, but she let me down big style last wednesday morning, conking out at 05.30 on the way to work leaving me no choice but to walk to work and come back in the evening to try to start it or recover it home, needless to say it wasn't play ball and green flag return her home. I'm not pee'd off as it has only failed to get me were I want to go twice in the 6 years I've had her and both times it has just cut out and will turn over but will not fire, checked for spark ok, checked for fuel no pressure at fuel rail, this could be down to the wiring to the main relay ( as was the problem before ) as the wiring here is pretty crusty so I was thinking of a bit of a re-work here and was wondering if anyone has any links to sites that can supply replacement electrical connectors to OEM specs?
injector driver relay perhaps?
MoleT-5R (Saturday 7th December 2013)
relay 108 first point of call
Looking good..
T5frankie (Saturday 7th December 2013)
Jumper out the fuel pump relay (the red/pink relay), if it starts get a new fuel pump relay, don't drive it about with the relay base jumpered out as the only way to switch the fuel pump off is to turn off the ignition - If it still won't run with the fuel pump relay jumpered you need to check for +12V on the pins of the relay base then check +12V is actually getting to the fuel pump tank connection - Mike
fuel pump relay ok, swapped for another, power to fuel pump, pump earth ok, fuel pump would appear to fubar'd, will swap for one out of the V70 I have here for the manual conversion for the V70R AWD what a good time to have a pile of spares around
T5-R alive and kicking, thanks to the donor v70, fuel pumps life was 262,000 miles not too bad, time to rebuild the orginal with a walbro 255 unless anyone has a better alternative ????
Good stuff an easy fix, she lives to fight another day
MoleT-5R (Sunday 8th December 2013)
Oh Yes, just traced the wiring back checking or swapping components along the way, but pump failure at 260,000 miles,I should write a stern letter of complaint to Volvo and demand a new V60 r design as compo..... lol
Still have to make good the wiring harness so still on the look out for OEM wiring connectors and boots to repair the old harness, if anyone knows where to get them??
AndysR (Sunday 8th December 2013)
MoleT-5R (Monday 9th December 2013)
Erm probley about 8mnths ago was only in car for less than 1ķ
Glad it was an easy fix for you Ade, looking forward to racing you next year.
