Results 1 to 8 of 8
    230K, aiming for 300k!
    Sep 2009
    Shrewsbury
    11
    D5 Dipstick Length
    I have a 2003 V70 D5. I recently had the head snapped off the dipstick, so my local indie popped one from an 850 in just to plug the hole. When I came to buy a replacement recently it turns out that Volvo changed the length for my model year. With this changed dipstick length came a change in tube length. I'm reasonably sure mine is the original longer length. However I have no idea if the ebay dipstick I have purchased, apart from coming from a 2003 MY car, is the right length for my tube.
    Can anyone with a 2003 D5 sick a tape measure on their dipstick an tell me the following lengths (measuring only the metal rod, not including the plastic bit):
    Overall length
    Length to max
    Length to min
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,487
    Mines a 2004 D5 - not sure if it's different - but my measurements are:
    Overall Length(metal rod only): 477mm
    Length to Max: 60mm
    Length to Min: 30mm
    Dipstick part number: 8699543
    Hope this helps.
    Steve
  3. The Following User Says Thank You to stephenevans99 For This Useful Post:
    JimmyBurnWorld (Sunday 28th July 2013)
  4. #3
    dtp's Avatar
    Feb 2009
    Malvern
    23
    Surely it's got to be long enough to reach the oil
  5. #4
    Sep 2009
    Shrewsbury
    11
    Thanks for the quick reply Steve.
    Quote Originally Posted by dtp View Post
    I don't know, my engine's on it's way out!
    Just checked the measurements of the replacement I have. It has a part number of 21439543 (compared to the number in the pictures above: 8699543
    The measurements however seem to be the same. 477 rod length, 38(ish)mm to the min, 60mm to the max.
  6. #5
    Swollen Member
    May 2006
    1,487
    I don't think you can go wrong with the dispstick you have - at least when it's showing minimum you still have that 8mm until it's on it's 'true' minimum.
  7. #6
    Mar 2013
    21
    Common rectification on all D5 , some of them have a factory sticker to read different levels,and careful too much oil in a D5 = problem
  8. #7
    all work n no play in car no
    fun at all
    copie22's Avatar
    Apr 2013
    north lincolnshire
    46
    to much oil in any engine = problems no mater what engine
  9. #8
    Sep 2009
    Shrewsbury
    11
    Quick update.
    My car is in for it's 234K Service tomorrow, so I wanted to make absolutley sure it had the correct dipstick fitted. Phoned Holdcroft in Stoke and got quoted £47 for Dipstick, Replacement Tube and Seal. Swapping out takes all of 10 minutes with a 10mm socket and a good tug.
    Annoyingly, at some point in my vehicle's life, it's already had the mod done to it. When I got the old tube out and laid it side by side with the new one they are identical lengths, however they have different part numbers.
    So, part number re-cap;
    Dipstick tube:
    As fitted to car (replaced some time after leaving the factory) - 30637374 - Googling this number results in lots of Russian pages.
    Replacement (as per dealer computer) - 31251092
    Dipstick:
    As fitted after ebay purchase - 21439543 - Scantech part Linky mmm, stick butter
    Replacement (as per dealer computer) - 8699543 - Equivalent part to already fitted.
    The seal for the tube is part number 30637865
    The part number for the tube (for anyone wanting to check before they part with cash) is stamped into the bracket next to the wiring loom which holds the top part of the tube stationary. Mine was pretty gunged up and needed cleaning up and a good angle with a torch to see.
    Hope this helps someone at some point.
  10. The Following User Says Thank You to JimmyBurnWorld For This Useful Post:
    stephenevans99 (Monday 2nd September 2013)
