Page 1 of 6 123 ... LastLast
Results 1 to 20 of 106
Thread: will it work???
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    will it work???
    XC90 brakes on a V70 with 17" wheels...
    What do we recon? Worth a go?
    336mm disks, mahoooosive calipers, 17" Ameltheas....
    Hmmmmmm.....
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    Ermm.... why not measure the gap between the current discs and the wheel first?.. presuming it's got 302's on it (or where the later cars bigger?) then you have a starting point and you can work out your clearance.
    Previous cars:
  3. The Following User Says Thank You to Tomcat For This Useful Post:
    M-R-P (Monday 22nd July 2013)
  4. #3
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Not to sure as the S60R with 17" Pegasus rims there is only a 3-4mm gap from rim to calipers.
  5. #4
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by Tomcat View Post
    305mm mate
    Indeed, this thought has crossed my mind...
    310.2bhp / 333ft/lb
    SOLD
  6. #5
    Jul 2011
    Poole, Dorset
    6,548
    305mm on the left, 336 on the right...
    310.2bhp / 333ft/lb
    SOLD
  7. #6
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    305mm mate
    But is the steel caliper smaller than the alloy ones on the R's or just get a set from a R !.
  8. #7
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Do you have the calipers aswell
  9. #8
    Jul 2011
    Poole, Dorset
    6,548
    Maaaayyybe
    310.2bhp / 333ft/lb
    SOLD
  10. #9
    Jul 2011
    Poole, Dorset
    6,548
    310.2bhp / 333ft/lb
    SOLD
  11. #10
    Jul 2008
    0
    I have 320's under my amaltheas and 336mm XC90 carriers ready for when they next need changing. Happy to send you the carriers if you want to try it (you will need the calipers obviously). Plod T5's (320mm) and 316mm or 336mm XC90 discs all used the same enormous calipers. There is a lot of room under amaltheas even with my 320's. Tim Williams sourced my current set and the set on my T5.
    2005 (163) V70 D5 SE Premium Pack 130k. 10" sub/Fli amp with Grom audio kit. Shark stage 1 with EGR delete and 320mm discs. Enjoying the comfort and (relative) economy.
  12. The Following User Says Thank You to jardon For This Useful Post:
  13. #11
    Jul 2011
    Poole, Dorset
    6,548
    So, the main opinion is that I should give it a go...?
    Hows this then?
    I've painted the calipers since the test fit
    Stay tuned, I'll be fitting them this week.
    310.2bhp / 333ft/lb
    SOLD
  14. #12
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Did you have to drill the hub out ? was it alloy or steel ?
    Looking good
  15. The Following User Says Thank You to oblark For This Useful Post:
  16. #13
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by oblark View Post
    Looking good
    It was just a test - fit mate. I put the 12mm bolts through and sat it on them. It'll need drilling tho, not a problem, there's plenty of meat on the hub. Still haven't decided if it's ally or steel - I didn't check lol.
    310.2bhp / 333ft/lb
    SOLD
  17. #14
    Jul 2008
    0
    Hub is aluminium and easy to drill. However, the steering deflectors are steel and I blunted several expensive 14mm bits before taking them to friend who used a very slow pillar drill which just glided through. All my drills at home are way to fast for steel.
  18. The Following User Says Thank You to jardon For This Useful Post:
  19. #15
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    336mm work well on my 850, people keep telling me its impossible to fit them under Volans..... Hope you get them sorted.
  20. #16
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by jardon View Post
    Hehe! I have the steering deflectors to go with the calipers
    However... I work in maintenance for a big steel fabrication firm so I have access to a plethora of industrial-strength toys
    Quote Originally Posted by Nealevo View Post
    Nothing's impossible, merely expensive (not always expensive - I got this kit for a very good price ) It's just a matter of drilling the hub and plumbing it all in. I hope to get at least one side done tonight.
    Pics to follow
    Good effort getting them under Volans, that must be bloody tight. I don't remember noticing the brakes when I saw your car tho mate - sorry.
    310.2bhp / 333ft/lb
    SOLD
  21. #17
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Hope it all goes well mate, may have to look into doing this to the C70. BTW if you haven't already, it's the ideal opportunity to upgrade to braided hoses.
  22. #18
    Jul 2011
    Poole, Dorset
    6,548
    Do try to keep up mate lol...
    Linky
    I'm hoping that, since the new calipers have the hose connection in roughly the same place AND they are slightly closer to the inner arch, I can reuse my braided hoses and maintain the bling factor
    310.2bhp / 333ft/lb
    SOLD
  23. #19
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Looking forward to seeing how you get on, hopefully no problems.
  24. #20
    Jul 2011
    Poole, Dorset
    6,548
    If I have any trouble, it'll be with the brake hoses. I have the XC90 hoses that came with the calipers but they look far too long for a lowered V70.
    310.2bhp / 333ft/lb
    SOLD
