Results 1 to 6 of 6
    V70 R ish
    thewatsonsmouts's Avatar
    Feb 2013
    6
    Red face Steering Rack.......Pls help
    What the easiest way of aligning the rack with the steering wheel? When tracked up I have about a 20mm difference in rods. Is it by dropping subframe again, and knuckle linkage off centralising steering wheel and aligning rack by measurement on the end of the inner rods? There is a machined flat on the steering rack spline pinion which I guess is for the bolt on the steering knuckle think I only have 1 or 2 splines of adjustment
    Ben Watson
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    I always put the steering lock on before i drop the rack/subframe with the steering wheel central
    kyboy's Avatar
    Jul 2010
    Mansfield
    165
    How much of a job is it changing racks? As I've got to do mine,any advice??
  4. The Following User Says Thank You to kyboy For This Useful Post:
    thewatsonsmouts (Wednesday 24th July 2013)
  5. #4
    Junior Member
    Jul 2013
    Gloucester
    6
    might be better to get a garage to fit in with a tracking machine to make sure its all done right.
  6. The Following User Says Thank You to Volvo_Mad For This Useful Post:
  7. #5
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by kyboy View Post
    may aswell drop the whole lot, engine and box either that or suspend the engine from a engine hoist or bar then drop the subframe.
  8. The Following User Says Thank You to merc85 For This Useful Post:
  9. #6
    V70 R ish
    Feb 2013
    6
    Undo the two front subframe bolts 20mm and take the rear ones out lowering the subfame down, obviously undoing the spline steering linkage. the two powersteering cooling pipes will also have to be undun along with the unions on the rack undo ya track ends and take them off then undo the rack itself from the subframe. I had to take the antiroll bar off out the way too to remove the heat shield plate this is a black plate one bolt on block and the other on the subframe/rack. I pulled mine out from the drivers side with a bit of higgery pokery isn't wasn't a bad job. got it all sorted now and she works a treat thanks guys for you advice
    Ben Watson
  10. The Following 3 Users Say Thank You to thewatsonsmouts For This Useful Post:
    kyboy (Thursday 25th July 2013),merc85 (Wednesday 24th July 2013),woody (Tuesday 3rd December 2013)
