Page 3 of 49 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 978
  1. #41
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Yep not bad at all one day to take all the under side off axel fuel tank etc and full interior out and another day to cut and weld the underside after that its the crap bit of striping all the old underseal off to replace with new
  2. #42
    Trader
    Nov 2010
    chester le street
    969
    burn it off with a butane turch if your brave enough. the type the roofers use. thatll make light work of it. i used to used stonechip and the paint the floor and arches using either hammerite if was white or 2k. with out doubt its the easiest. when my volvo got repaired a while back they used a ruber coating on the boot floor. its prevents it from chiping and looks like factory
  3. #43
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Yeah im going to give burning it off a go first and as for the under sealer I was thinking of getting a paint shop to mix a batch of under sealer the same colour as the car.
  4. #44
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Quote Originally Posted by t5 pete View Post
    Hopefully in a month or two once ive sorted the spare bedroom out I will make a start on the under side and get all that sorted rewelded and fully striped and new underseal also all new bushes on the read axel.
    Your gonna do the restoration in the 'spare room'
  5. #45
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by V70 Graham View Post
    Graham all that slow driving you do gives you way too much time to think
  6. The Following 2 Users Say Thank You to t5 pete For This Useful Post:
    Jamest5r (Sunday 7th July 2013),LiamT4 (Sunday 7th July 2013)
  7. #46
    Member
    Oct 2005
    3
    Hi,
    Good luck with this, glad to see it's not just me that tries to save them from rusting into the ground!
    Have you checked the odd curve in front of the front strut mounts, behind the black plastic box, on the drivers side, for rust? One of my guls has a hole you can put your fingers through in there.
    Looks like the inner wing liners don't stop crud from going up in there and getting trapped. Mine looked like it had rusty streaks down the inside, until I checked the back.... and then the crying started....
  8. #47
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by al c View Post
    Hi,
    Yeah its will be nice to bring the car back to how it used to be and how it should be. regarding the odd curve do you mean behind the ecu box?
  9. #48
    Member
    Oct 2005
    3
    Yes, if you look behind the ecu box and the expansion header tank, tucked up in the corner, and the same on the other side, the coumpound curve has rotted out on mine. If I could work out how to make my work network let me attach pictures I could show you better, pictures being worth a thousand words and all that.......
  10. The Following User Says Thank You to al c For This Useful Post:
    t5 pete (Wednesday 10th July 2013)
  11. #49
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    I found some rust thats starting behind the rear arch liner on the drivers side, it's not too far gone yet but it's certainly not surface rust. I always thought that these cars just didnt rust at all, apparently I was wrong.
    Previous cars:
  12. #50
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Tomcat View Post
    Any car made of steel is at risk of rusting, even galvanised ones, just some are higher risk than others.
  13. The Following User Says Thank You to stribo For This Useful Post:
    Tomcat (Wednesday 10th July 2013)
  14. #51
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Ahem ***ford***
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  15. The Following User Says Thank You to M-R-P For This Useful Post:
  16. #52
    Member
    Oct 2005
    3
    Yes, I was of the same opinion, before I started poking around too deeply. The other favourite seems to be the spacing bracket between the inner and outer wings, in front of the front wheels.
  17. #53
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Ahem ***ford***
    Earlier Fords definitely, my Cougar was half galvanised, as they all were but still rusted. Look at how bad the Mercs were in the 90's, and they cost alot more.
  18. #54
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    I always think about early fords when I think of rust, spent half my early driving days repairing rusty fords..
    Previous cars:
  19. #55
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    What most people seem to forget is that these cars are around 20 yrs old now so tbh they have done brilliant to get to this age look at a lot of other cars from the mid to eairly 90's they haven't faired so well.
    Best thing to do with our cars is when you first see rust get it sorted and not leave it or just give it a quick rub and hope for the best as that's how it spreads and gets a lot worse.
  20. The Following User Says Thank You to t5 pete For This Useful Post:
  21. #56
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Yeah you make a good point Pete, because they stand up to so much punishment and last so long everyone forgets just how old these cars are.
    Previous cars:
  22. #57
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Update time
    As I now have a donour car I needed to strip a few items off bumble bee (yes that's its name) to see the extent of the rust and what needed replacing tbh its not bad at all with most of the rust just being surface and will grind back to solid metal other areas will be cut out and replaced.
    I also started stripping the underseal off it wasn't too hard the scraper and angle grinder made short work of it and with a good rub down with brake and clutch cleaner it will be ready for primer then new under seal once all the repair work has been done.
    Any way piccys
    Rear bumper bracket
    And the bumper main bolts was a nice challenge to remove with out snapping
  23. #58
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Exhaust bracket may possible need a new one
    Wings
    Most likely the problem with the abs
    Zorst tunnel
    Nice and clean
  24. #59
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Next will be to drop fuel take and rear axel then a full strip of the under side.
  25. The Following User Says Thank You to t5 pete For This Useful Post:
    craigoodwood (Wednesday 31st July 2013)
  26. #60
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    I've taxed worse!!!
