Page 16 of 29 FirstFirst ... 6141516171826 ... LastLast
Results 301 to 320 of 573
  1. #301
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    Quote Originally Posted by LeeT5 View Post
    Cheers! It will hopefully look even better, once I finish it. Have got 1m of blue LEDs to be installed inside the air box. I know it's kinda pointless cos the bonnets shut etc, but I thought It would look great at a show or meet.
    Are you serious
  2. #302
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Yep, would look good with an orange engine bay. Unfortunately, my cars black and they don't do black led's......
    But they'd go with the interior.
  3. #303
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by MIKESC70T5 View Post
    Are you serious
    Ha ha, Mike. Trust me...if they look crap they won't stay on the car. TBH, it's just a bit of fun. Something different, a break from the norm etc. I know of nobody else that has done it other than someone in the U.S and to be fair it looked really cool.
    If it looks a bit, shall we say....Halfords, then I'll take 'em off. I just think they might add a bit of 'ooooohhh niiiiccceeee!!!' under the bonnet, without decorating the engine bay in LEDs. It will be very subtle...I hope.
    If not, you'll be the first to know and I'll tell you you were right!
  4. The Following User Says Thank You to LeeT5 For This Useful Post:
    MIKESC70T5 (Tuesday 14th July 2015)
  5. #304
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Thought I'd update as I've not been here for a while due to recent house move.
    My car is currently In Volvo have a massive brakes overhaul. It was never going to pass the MOT in November as the handbrake cables have been seized and binding for many months now. I've just not had time to sort it out, so I basically stopped using the handbrake and just left it parked in 1st. However, It needs to be sorted, obviously. I also wanted to replace the discs as they have now done two sets of pads on the front and I doubt they'll last a third. The rear shoes are also knackered and the brake fluid was picked up on the 144k service as +5% ingress, so that needed to be changed as well....so I have instructed Volvo to do the following at a very preferential rate (cheaper than your average Joe garage)
    1. Remove and replace worn discs and pads (all round) with these...
    Genuine Brembo drilled 330mm + Brembo pads
    2. Replace brake fluid with ATE super blue dot5.1 synthetic (already used and I'm supplying)
    3. Replace handbrake shoes with new (dealer supplied)
    4. Replace P2 handbrake adjusters with P1 model adjusters (dealer supplied)
    5. Replace all 3 handbrake cables with new cables (dealer supplied)
    Whilst it's in, they have given me a 15 plate V40 D2 R-Design....Nice, but underpowered
    I pick it up tomorrow morning.
    Due to my moving house, I needed to transport some ladders, so I bought some of Thule's finest Wingbars. At 80mph...absolutely no wind noise!
    Finally got rid of my old knob...
    ...and replaced it with.....
    I also got round to re routing my TCV to the stock location with some nice new shiny silicone...
  6. #305
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    1. Fit 6000k HID fog lights - (COMPLETE)
    2. 3" downpipe --(in the new year)
    3. 200 cell race cat --(in the new year)
    4. Fit Volvotech CFE --(COMPLETE)
    5. Handbrake mod P1 Adjusters (COMPLETE)
    6. Replace windscreen --(in the spring)
    7. New leather OE gear knob --(COMPLETE)
    8. Refit rear mudflaps --(COMPLETE)
    9. Fit magnetic engine oil drain plug on next service --(COMPLETE)
    10. IPD Rear adjustable toe rods --(Need to order)
    11. IPD DEM alloy cover --(need to order)
    12.
    13. larger exhaust tips
    14. Fuel filter bracket and bolt -- (COMPLETE)
    15. Fit stock air box once acrylic window mod -- (COMPLETE)
    16. Fit Blue Jetex cotton filter -- (COMPLETE)
    17. Swap Forge CBV yellow spring for blue spring (17psi).
    18. 144k service at Dealer (COMPLETE)
    19. P/S fluid flush (COMPLETE)
    20. Fit BREMBO drilled discs and pads -- (COMPLETE)
    21. Fit D5 oil cooler -- (COMPLETE)
    List of jobs is getting rattled off!
  7. The Following User Says Thank You to LeeT5 For This Useful Post:
    stribo (Thursday 8th October 2015)
  8. #306
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Have you joined the silicon vac pipes to the standard ones?
  9. #307
    "The Instigator"
    The Flying Moose's Avatar
    Sep 2008
    Norwich, Norfolk
    2,842
    Lee looking amazing as ever, your car has always been my favourite v70r.
    The big question is how do you manage to get a decent rate from Volvo!
    Arguing is pointless....she may not be right but she's never wrong
    Tell her a remap is just having your satnav updated.....
  10. The Following User Says Thank You to The Flying Moose For This Useful Post:
    LeeT5 (Thursday 8th October 2015)
  11. #308
    Feb 2012
    135
    Quote Originally Posted by The Flying Moose View Post
    Lipscombe have offered cheaper rates for years to those in there club...when i belonged to it in my 960 days the MOT was FREE but they were losing out as all the models were the older ones then and not Fords...Lol
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  12. #309
    Aug 2015
    Herne Bay, Kent
    0
    Where did you get the discs from? I need to replace my front ones and want drilled discs...
  13. #310
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Yes mate. The black vacuum hose that connects the turbo is all new from the dealer and as you well know, the red line is a mother F... to get to on the turbo, so best left alone. The TCV was cable tied to the strut brace when I had my AMS, so that's why the hoses were shorter. I cut them to the same length and joined the silicone at the same fixed point, making for a simple and clean install. Used proper inline hose joiners and hose Spring clips.
    I've been a loyal customer to Volvo since 1990, when I bought my first 440 GLT off their forecourt for £8k.
    I'm also a member of their 'plus 4 club' which officially gets me 25% off labour and 12% off parts. Unofficially, I have been known to get as much as 66% off labour rate!!
    Quote Originally Posted by kevinking2020 View Post
    Search for item number 251727107751 on EBay.
    Can only buy a full set not just fronts or back. £399 delivered free.
  14. The Following 2 Users Say Thank You to LeeT5 For This Useful Post:
    stribo (Friday 9th October 2015),The Flying Moose (Thursday 8th October 2015)
  15. #311
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Fitted new under bonnet sound proofing, which has been modified to allow for the OTE pipe and stock airbox. It's very common for the OEM part from production to rub on the OTE bracket and OTE pipe. Part comes with new clips!
  16. #312
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Car passed MOT on Friday. Whilst I was there I had my winter wheels and tyres balanced and fitted.
    After the MOT, I had my car re mapped. . (details to follow).
  17. #313
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    This is one well cared R.Seen it in the flesh,nice work Lee.
  18. The Following User Says Thank You to Kingsford G For This Useful Post:
    LeeT5 (Tuesday 24th November 2015)
  19. #314
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    CFE removed and updated the software from v9.20 to v9.54.
    I'm now able to turn 'on' the approach lighting when I unlock the car. This would previously only work when you pressed the yellow button.
    Approach lighting includes front fogs, dipped beam headlights and reverse lights.
  20. #315
    Aug 2015
    Herne Bay, Kent
    0
    Where did you get the remap from Lee?
  21. #316
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    http://www.jfautomotive.co.uk/
    This video to wet your knickers.....
  22. #317
    Aug 2015
    Herne Bay, Kent
    0
    Very nice! What did you make? Previous owner already remapped my car but no dyno print. According to owner it's 340BHP and 470NM.
  23. #318
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Not had it dyno'd yet mate, thou it's on my new year 'to do' list.
    According to BSR, my stage two remap was 354bhp/498NM. I can assure you that the new custom map is exceedingly better than that. It's definately quicker, more responsive, much more boost and definately more torque.
  24. The Following User Says Thank You to LeeT5 For This Useful Post:
    Nealevo (Friday 4th December 2015)
  25. #319
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
    That's interesting. The bonnet lining on mine rubs on the OTE pipe near the front.
    Where did you get it?
  26. #320
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Looks like they have done a update again.
