Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Suspension
  1. #21
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    Quote Originally Posted by partsforvolvos.com View Post
    Volvo do list standard shocks for AWD 850/v70 models.
    other countries , particularly Australia had cars without nivomat where our uk models got it as standard.
    the difficult bit is getting the spring code number to order the standard spring that is correct .
    Since doing my homework on it I've discovered that our European r models (ph1 anyway) have a lowered ride height than other countries. It was a specified option I believe in the states.
    It is a good idea with the bolts, i cant take credit for that though. lol I'm half tempted to make some solid poly mounts for it to sit on with holes through them to act as a sleeve. I have some very hard wearing stuff in work that's used on the mountings for the landing gear on a a380 so guess it would stand the awd & suspension movement on my r.
    I won't be fitting them until I source some front shocks & springs though & that will probably be after my wedding. Lol
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  2. #22
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    I've also seen the price of the springs to match if you get the right ones. Uprated or tuner springs are rare & expensive but I don't see why a custom set couldn't be made. The spring shop on Fred dibna could work out poundage the length required etc. lol
    Previously:
  3. #23
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    Quote Originally Posted by bomb192uk View Post
    Yeah they're sort of easy to fit and not at the same time as you need to get the car high enough to fully extract the shock through the bottom of the suspension arm :/ But otherwise its 3 bolts and the thing drops out
    Good idea with the longer bolts/sleeves
    I can see that being a job for the big jacks in my mates then. Lol
    Thanks for the heads up on that one. It's an odd system & old school Volvo as I'm led to believe. Effective none the less. I just think my car needs to go lower. Lol
    Previously:
  4. #24
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    Quote Originally Posted by Biff View Post
    Yes, the suspension system was taken from the late 900 platform.
  5. #25
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    That can't be a bad thing at all.
    Previously:
  6. #26
    New Identity
    Dec 2006
    West Midlands
    2,491
    Indeed, the diff was also borrowed from the 900 series too
  7. #27
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    shame about the fact they used the viscous coupling from a rubber jellyfish.
  8. #28
    New Identity
    Dec 2006
    West Midlands
    2,491
    PMSL
    It works though :/
  9. #29
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    I thought it was made of chocolate? I will find out soon, I've sourced some angle gear & a prop, all working on a breaker. I'll need a collar from the gear box to the angle gear then I should be ready for what ever winter can throw at me!!
    Previously:
  10. #30
    New Identity
    Dec 2006
    West Midlands
    2,491
    New one from Volvo is around £90
  11. The Following User Says Thank You to Dangerous Dave For This Useful Post:
    Biff (Monday 24th June 2013)
  12. #31
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    Worth it for the reassurance really.
    Previously:
  13. #32
    My Car Will Never Be
    'Finished'
    Dan H's Avatar
    Mar 2013
    Stockton
    20
    Good shout with the collars for the bolts, I'll invest in some of them, may get on the look out for some front lowering springs too (I know i should get the right spring rate but I've never had any problems with any of the other cars I've lowered using different spring rate to standard
    Cheers for the Help guys!
  14. #33
    New Identity
    Dec 2006
    West Midlands
    2,491
    As Biff has said, the R AWD is lower than the standard AWD (not sure how much) so you could get the R springs.
  15. The Following User Says Thank You to Dangerous Dave For This Useful Post:
    Biff (Tuesday 25th June 2013)
  16. #34
    Meh.....
    Biff's Avatar
    Dec 2012
    2,528
    It's not a lot, about 30mm but sure if you uprated the dampers it would match up ok.
    Good luck with the lowering of the rear, if you carry out the mod before me please come back with lots of pictures & a before & after.
    I've got to wait till oct before I do mine you see.
    Previously:
  17. The Following User Says Thank You to Biff For This Useful Post:
    Dan H (Tuesday 25th June 2013)
  18. #35
    'Finished'
    Dan H's Avatar
    Mar 2013
    Stockton
    20
    I should hopefully have mine done by end of august! I'll be happy with 30mm lower than what it is now, don't want it silly low, past that stage now, but yeah I'll try to remeber to get some pictures, before, during and after.
