Can anybody shed some light onto what the difference is between AWD suspention and normal 2wd suspention? Apart from the spring rate, what are the other differences?
I can't , sorry lol
T5RatherAmusin (Monday 24th June 2013)
Oh, some 2WD cars had Nivomats too, as far as I'm aware they're the ex-plod machines. MRP will no doubt give you a dissertation on Nivomats and AWD suspensions....
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
p fandango (Monday 24th June 2013)
The front suspension isn't any different to the FWD apart from the springs are different to make the car higher.
As has been said, the rear suspension is a completely different setup, there is a frame built around the diff which contains the shocks, springs, wishbones, etc. The rear floorpan of the car is different with mountings for the suspension/diff unit.
The petrol tank is also different, it sits like a saddle tank over the front of the diff/viscous coupling. The rear brakes are use 283mm discs and different calipers. The exhaust comes straight off the cat along the propshaft and over the N/S suspension to silencers behind the rear bumper.
HTH
It's different as been said. Lol
I've been working on some "drop bolts" to lower the rear of mine by 2" to level it out with 40mm springs when I hopefully find a pair.
As said its self leveling which will drop when you chuck a weight in the boot but levels out once you've driven round the block.
Some say its better but I don't see how it's better than a decent top spec coil over which along with an uprated damper are obsolete for this car unless you want to remortgage & ruin the ride.
missing being Swedish
Previously:
03 S40 Sport Lux 1.9d SOLD
1998 V70R AWD Manual BROKEN
Dangerous Dave (Sunday 23rd June 2013)
I replaced the Nivomats on my awd, £360 (and that was discounted from over £500, though they were genuine)
Biff (Sunday 23rd June 2013)
Previously:
LOL, got them from FRF Swansea (via Rufe) was surprised at the discount (pretty sure I have got the price right) but it was a few years ago now (think it was around 2008).
Mine were knackered, oil all over them and dust boots were shredded
Biff (Monday 24th June 2013)
I'll bare that in mind. Cheers.
Previously:
Dangerous Dave (Monday 24th June 2013)
They do a great service and delivery is quick (even with stuff from Sweden).
I did have a trawl through ebay and find some cheaper pattern parts though, the price has really come down these days.
Having had a nightmare with dodgy pattern parts (maf & radiator x2, idle control valve) I'm trying to keep it genuine as I replace things or uprate with decent spec mods. It's not cheap at all but I want the old girl reliable & genuine incase dread the thought I'd have to sell her I could show the receipts for 000's. lol
Previously:
Can u not chop the rear springs lol
No mate, the nivomats will stay at the same height & it would shag the rebound up. Easiest way is the drop bolts, you get the same suspension travel with a lower ride height & the cost is 2 bolts and a few nuts or a sleeve to slide over the thread. Basically it fools the nivomats.
Nivomats look like they're upside down, this is the mounting from underneath the car.
The 2 bolts are what you need to lengthen & the sleeve or row of nuts needs to sit under the mountings shoulder if you get me?
Excuse the state of that photo, I borrowed it & my photobucket isn't a fan of edited pictures on my phone. Lol
Previously:
I was going to do something similar with my P2, using brackets to drop the bottom of the niv by about 65mm but I got lazy and just fitted lowering springs and OE rear shocks giving me about 70 - 75mm drop at the back
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Volvo do list standard shocks for AWD 850/v70 models.
other countries , particularly Australia had cars without nivomat where our uk models got it as standard.
the difficult bit is getting the spring code number to order the standard spring that is correct .
