Results 1 to 18 of 18
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Thumbs up Powerflex Top Engine Mount Bush and Strut Brace Tensioner Bushes fitted today....
    I thought I'd go out and finally do a job I've had an absolute hankering to do for a while, and that was to fit a Powerflex top engine mount bushing along with Strut Brace Tensioner Bushings. I just felt the engine bay needed 'tightening up' a bit and this certainly seemed like a good start.
    So I went on line and brought these, the Powerflex Black range which as a lot of you are aware already is a 'teeth chattering' 80% stiffer than rubber and 25% stiffer than Powerflex Purple.....
    So all I needed was a 15mm, 17mm and 18mm spanners, a hammer/mallet and a flat headed screw driver. I initially took off the top plastic cover under the boost pipe as I felt it gave me more room but in the end it wasn't necessary. I removed the black engine mount bar which was a pretty easy job.......
    Took out the old rubber bushing, this was really easy just knocked the end plate off with a flat headed screw driver and the mallet and pushed the bush out by hand, I was like "OMG, that easy"!.............
    Then I used the copper slip provided with the bushes to grease up the Powerflex bush and pushed each section in to the gap, again this was really easy and required hardly any effort........
    Next the metal rod goes in (again copper slipped it first).....
    Then I fitted the strut brace tension bushes (they go in to the underside of the side mount), and then put the black bar back on doing up all the bolts and nuts tightly....
    I even had time to give the car a Rapid Detail today and all is well......
    As for the 'feel', there is definitely more vibration through the cabin now from the engine but that engine mount bar is much more solid that it was, in fact it takes some effort now to get it to move more than just a few millimetres where are before I could rock it back and forward quite easily. The difference is certainly 'night and day'!
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    i upgraded all my Powerflex bushes on the 850 from there normal ones to the Blacks, working with both sets side by side it amazed me how much more solid the Blacks are
    i keep threatening to get another set of engine bar bushes for the S60, i knackered the first set trying to get them into the top of the bar lol
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    The Blacks are rock bloody solid. To start with I though there was a problem with the engine until I realised that actually there is very little budge in the Powerflex bush. The vibration is only really noticeable at idle though and to be honest I kind of like it because it reminds me of what I've just done and now much more solid the engine mount now is. An easy job for anyone too so it's well worth it, unless of course someone wants to get it done by a Volvo specialist!
    p fandango's Avatar
    Aug 2004
    4,216
    i've got Blacks on the engine top mount, bulkhead (850 so doesn't go to the engine bar like yours) & both gearbox tie-bar bushes. Plus the front engine mount is literally a solid bar now. Think i might quite a bit of vibration lol
  5. #5
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Must say my purple one hardly increased the cabin noise at all, nice and quiet.....just how I like it.
  6. #6
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Looks good ill await your thread on my t5 is rattling/knocking again lol
  7. #7
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    The washers on the strut - brace / engine brace are meant to go below the powerflex rings not above the alloy mounts. Or the powerflex rings will fallout.
    The washers are dished to tighten up to the powerflex bush.
  8. #8
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Oops!
    Best get that sorted soon James, you don't wanna loose £25 of powerflex on the road like I did with a HID ballast the other day
    Good work otherwise, I'm surprised you went for the black series, the vibration from the yellow top mount bush annoyed the hell out of me til I fitted the strut brace tensioners.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  9. #9
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Well given that it says "Fitting Instructions Inside" and there weren't any, I double checked another Performance Volvo site (T5/D5 I think people call it), someone said to fit the ring on top. Looks like some forum advice isn't worth following...... Anyway, I'll see if I can rectify the situation before my trip to the Midlands later today.
  10. #10
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Oops!
    The vibration is great, I've now got a built in massage chair! Anyway, this Black range is superb and well worth the extra few quid, there just is no budge in it at all and if I'm going to stiffen the car up I'll be using black where it's available.
  11. The Following 2 Users Say Thank You to JamesT5 For This Useful Post:
    M-R-P (Saturday 22nd June 2013),p fandango (Saturday 22nd June 2013)
  12. #11
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by JamesT5 View Post
    James are you going to do the 2nd bush on the engine brace bar as it won't last to long with large black bush fitted in the top engine bracket.
    It's also worth changing the brace bushes under the engine/gearbox.
    Old M-R-P how to do post .
    http://www.vpcuk.org/forums/showthre...l=1#post422300
  13. #12
    Trader
    Nov 2010
    chester le street
    969
    i might get the yellow one. get a timing belt cover on your shopping list. not a good idea to keep them exposed.
  14. #13
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    Looking good James. I had a yellow one on my p1 v70 and that sounded nice in the cabin. Mine needs the lower front one replacing so will be doing top and bottom soon. Will look into the black series when I get them.
    It's a 5 Cylinder Orchestra!
  15. #14
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by graemewelch View Post
    Don't need to buy one, there's one fitted to my car already that I just removed as a means to an end to get the main cover off.
  16. #15
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    I did wonder whether there was a bush available for that back section but just haven't noticed it. I'll be buying one on pay day in that case!
    The bottom brace I've already changed for a standard rubber one but I plan to poly up the old one and refit it to the car. It's on my to-do list.
  17. #16
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by jdavis View Post
    I think people under estimate just how hard the black powerflex stuff is, the dashboard and glovebox now buzz at idle or very low rpm.
  18. The Following User Says Thank You to JamesT5 For This Useful Post:
    jdavis (Sunday 23rd June 2013)
  19. #17
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Problem solved yesterday before my trip to Walsall, took me 10 minutes!
  20. #18
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Well i went from the purple strut brace bushes to these:
    i gotta say the difference was night and day. Steering is a lot more sensitive and responsive. Also, cured 80% of rear end stability 'Side hop'.
    A vast improvement. I know they are expensive but well worth the money and 100% improvement on a poly bush!
Tags for this Thread
