Right, next task...exhaust and ECU!
I've spoke to Jan Woth from WothRline and a helpful guy called Thomas in TME, plus also emailed Don from Kalmar Union, and I think I have some idea about what go for next. The exhaust tail pipe is a bit scabby anyway (good excuse)....
Jan thought about 270 hp and 400 Nm with a remap and a catback exhaust. TME said a little higher if the downpipe and cat are replaced also....but not cheap.
I was interested in those Turbo Tuner things but maybe a little beyond my skills at the moment...maybe later. First I think will try and scrape the cash together for both an exhaust and a remap from TME.
Some advice from TME:
You will need to secure the "christmas tree" caps. You find it next to the throttle body under the black cover. Those rubber caps have a tendency to blow off with more boost. Also replace all thin vaccum hoses from the TCV. A vaccum leak will reduce hp and go into safe mode. This can be reset by removing the ECU wait for a minute and put it back in. The ignition key must always be away from the car everytime the ECU is removed.
[I assume Thomas was Swedish, almost impossible to tell from the techncial English above...it's embarrassing how good people who are not from our country can speak our language]
He also mentioned that max boost would be increased to 1.2 barg. I'm not sure what standard boost is around 10 psi according to a net search.
