Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: running issues
    JT's Avatar
    Jun 2010
    sussex
    1,641
    running issues
    Hi all
    I have problems........with the black 850, lol
    It was running fine on Friday,filled her up with tescos best and put a detox/cleaner in it.
    On the way to Brooklands yesterday,I noticed it was starting to cough a bit at 3500 rpm
    this got gradually worse,to a point where I had to pull over and check something hadn't come off.
    Didnt find anything.
    Limped on to Brooklands and we only just got there at which point the lambda light had come on.
    When we went to leave it wouldnt start and when it finally did,it was really rough.
    I couldn't really touch the throttle as it would cough and splutter really badly,hence to say the drive
    home was not much fun.
    So today I have changed:
    fuel filter
    all 5 injectors
    fuel rail
    fuel reg
    IDC
    MAF
    Lambda sensor
    ECU
    all with no joy
    any ideas anyone?
    what have I missed?
    cheers
    JT
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Cat blocked???? I've had this on another car same issues???
  3. The Following User Says Thank You to Nealevo For This Useful Post:
    JT (Sunday 2nd June 2013)
  4. #3
    JT's Avatar
    Jun 2010
    sussex
    1,641
    really?
    oh crap
    cheers Neal
  5. #4
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Have u read the engine codes?
  6. #5
    JT's Avatar
    Jun 2010
    sussex
    1,641
    Quote Originally Posted by p fandango View Post
    Black has the OBD 2 port
    I dont have a reader for that
  7. #6
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by JT View Post
    https://www.box.com/shared/oy63haaef2
  8. #7
    JT's Avatar
    Jun 2010
    sussex
    1,641
    yea right! lol
    isnt there a proper code reader flying about on this forum somewhere??
  9. #8
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Try some fresh fuel
  10. #9
    JT's Avatar
    Jun 2010
    sussex
    1,641
    Quote Originally Posted by oblark View Post
    Try some fresh fuel
    I have thought of that Rob,but with 3/4 of a tank in there,not sure I want to waste all that! lol
    but I might top it up with fresh stuff and see what happens
  11. #10
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    Think I'd get the codes read, then if that doesnt bring up anything I'd drain the tank and try some fresh stuff. You didn't put too much cleaner in it did you?, sounds coincidental that it started playing up shortly after you filled up. What colour was the sparks plugs and the lambda when you pulled them?..
    Previous cars:
  12. The Following User Says Thank You to Tomcat For This Useful Post:
    p fandango (Sunday 2nd June 2013)
  13. #11
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Have you checkedf the ignition side? Could be coil, rotor arm, dizzy cap.
  14. #12
    JT's Avatar
    Jun 2010
    sussex
    1,641
    well when it starts, it will tick over like normal,so I think they are all ok,
    its only when I touch the throttle it seems to choke itself and the point of the Lambda light is up,makes me think Neal could well be right
    I did check all the leads etc were where they should be,but I havent replaced any..........yet
  15. #13
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Before I changed my plugs, leads etc. mine would start fine and run fine when cold, but once warmed up if put under any load would misfire badly, although it would run fine on part throttle. As has been said above though it could be the cat.
  16. The Following User Says Thank You to stribo For This Useful Post:
  17. #14
    Driving old Volvos, because im
    cool!
    timbo's Avatar
    Mar 2012
    Doncaster/Lincoln
    205
    This bloke (ripsta33) used to sell the code readers on eBay for £14.99, don't know if he's got any left??
    http://www.volvoforums.org.uk/member.php?u=16551
  18. The Following User Says Thank You to timbo For This Useful Post:
  19. #15
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Mine used to do that, changed the plugs an all was perfect.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  20. The Following User Says Thank You to claymore For This Useful Post:
  21. #16
    Moderator
    NOS
    WOODY T5's Avatar
    Sep 2005
    hull
    2,573
    Idle con valve !
    "WOODY T5 fastest volvo 850 since 2011/12/13/14 @ avon and york 13.3 112mph
    854 t5 19t gripper mte bc loads more 311.6 whp 373 foot pound 342 @ clucth
    toy cbr954
  22. The Following User Says Thank You to WOODY T5 For This Useful Post:
  23. #17
    JT's Avatar
    Jun 2010
    sussex
    1,641
    thanks for all the input
    I will change plugs n leads tomorrow
    fingers crossed
  24. #18
    p fandango's Avatar
    Aug 2004
    4,216
    fingers crossed
    hows the missus going to get to work? lol
  25. #19
    JT's Avatar
    Jun 2010
    sussex
    1,641
    I would rather walk than drive her 1st option! lol
  26. The Following User Says Thank You to JT For This Useful Post:
  27. #20
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Split intercooler hose perhaps bud? will flag a light due to runing lean, check your boost hoses and intercooler buddy
  28. The Following User Says Thank You to merc85 For This Useful Post:
