Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Bird is the word!
    dionbullock's Avatar
    Aug 2008
    north wales
    92
    Took a picture of how i got the rear spring out, not the bottle jack! ingenious solution!
    And on another note, The car had massive knocking noises from the rear and i couldn't fathom what the hell was making the noises!!! Turns out, whichever numpty had changed the rear pads last had put the metal clip/spring on wrong, the long bit was on the outer edge of the caliper so there was no tension at all which meant the pad was vibrating/shaking in the caliper!! So i took the clip off and fitted it correctly (picture) and the rattle has gone!
    I will get some pics of how car looks later on hopefully!
  2. #22
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Cool! I used a bar to push the hub down, when that didn't work, I undid the lower arm.
    I did that with my front brakes - SERIOUSLY hampers braking performance lol.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  3. #23
    jez.w's Avatar
    Sep 2008
    Bedfordshire
    49
    Ahhh ok, my C70 which i intend to lower soon looks the same as my old 850. I wondered if the p2 v60 s60 were different by the way you described it.
    Jez
    C70 2.4T Manual
  4. #24
    Jul 2011
    Poole, Dorset
    6,548
    V60 is P3 and uses Mondeo suspension
    The C70 is largely based on the 850 with a few differences to make it look like they tried lol
    310.2bhp / 333ft/lb
    SOLD
  5. #25
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by jez.w View Post
    The 850 was very easy, i did it quickly without special tools, just need spring clamps. Replaced all the top mounts too (upper and lower) The rears were even quicker, just jacked up the back end and took the wheels off, then compressed spring and pulled it out (after undoing one clamp bolt on bottom of spring). Is it really much harder on P2? I want to do my C70 soon, i had a look underneath my C70 the other week and it looks exactly the same to me. I sure i can do the whole thing in a few hours no trouble. Is V70 different?
    I didn't use spring compressors on my C70, just jack the rear of the car up, undo the nut that holds the coil spring in its' seat (18mm i.i.r.c.) with another jack, jack up under the rear coil spring to take the tension of the shock/damper, undo the bottom shock nut, and pull it off the stub(you may need to loosen the 2 top bolts on the shock top mount to allow enough movement, I was changing shocks anyway so took them right out) then just lower the jack under the spring, and pull said spring out (It'll need a bit of levering, but isn't under any tension, so no danger). Transfer the upper spring seat and bump stop onto your new spring, replace new spring then bolt up the lower spring mount, jack it back up, whilst guiding the bump stop and upper spring mount back into place, refit the shock back onto the stub and bolt up, release the jack from under the spring, and job done, you don't even need to take the wheels off.
  6. #26
    Bird is the word!
    Aug 2008
    north wales
    92
    took a few grainy pics in the fading light last night of the 40mm drop. no "before" photos to compare though :/
    Name:  Volvo lowered 1.jpg
    Name:  Volvo lowered.jpg
  7. #27
    Jul 2011
    Poole, Dorset
    6,548
    That's better
    310.2bhp / 333ft/lb
    SOLD
  8. #28
    Junior Member
    johnnyb's Avatar
    May 2012
    0
    I've got a before and after with mine using the same springs if anyone is interested. Oh and I agree about the rear springs being a little tricky.
  9. The Following User Says Thank You to johnnyb For This Useful Post:
    dionbullock (Monday 3rd June 2013)
  10. #29
    Needs more boost
    danny-R's Avatar
    Jan 2009
    middlesbrough
    793
    Both look very nice. I really must pull my finger out and do mine
  11. #30
    Bird is the word!
    Aug 2008
    north wales
    92
    It's one of those jobs i should have done months ago!
    All i need now are some 18" pegs to finish it off!
  12. #31
    Bird is the word!
    Aug 2008
    north wales
    92
    Well after a couple of weeks all is well, apart from one little niggle...
    The rear has developed a squeek, firstly on the passenger now tonight its started on both sides... needles to say its VERY annoying!
    Im wondering if the springs are rubbing the cups or something. Or maybe i've fitted the springs upside down (if possible). there were more turns on one end compared to the other (see photo) and thats how i fitted them. Perhaps i should turn them around??
    Any suggestions would be of help!
  13. #32
    Jul 2011
    Poole, Dorset
    6,548
    More coils at the top mate, and use some grease
    310.2bhp / 333ft/lb
    SOLD
  14. #33
    Bird is the word!
    Aug 2008
    north wales
    92
    Ahh - lesson learned! Any particular type of grease?
  15. #34
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by dionbullock View Post
    Slippery type mate
    310.2bhp / 333ft/lb
    SOLD
  16. The Following User Says Thank You to M-R-P For This Useful Post:
    dionbullock (Wednesday 12th June 2013)
  17. #35
    Bird is the word!
    Aug 2008
    north wales
    92
    Changed the springs the right way round and put a load o grease there, took her for a test drive and she's still squealing like a bitch! I noticed one shock was alot easier to compress than the other. Signs of a worn shock?! Would that make it squeak??
  18. #36
    Bird is the word!
    Aug 2008
    north wales
    92
    Replaced the 2 rear shocks as they seemed pretty passed their best. Thankfully the rattles/squeaks have completely gone!
    I opted for some standard Monroe shocks, seemed good value for money!
  19. #37
    Jul 2011
    Poole, Dorset
    6,548
    Sorry mate - missed the last post. Glad it's all sorted
    310.2bhp / 333ft/lb
    SOLD
