Results 1 to 16 of 16
    hillsidesteve's Avatar
    Dec 2012
    BRISTOL
    73
    Thumbs up ME7 ETM cleaning
    Hi can anyone advise the easiest way to go about removing the etm so I can clean it hopefully to stop an erratic idling problem on my '99 T5
    Thanks in advance for any help
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Err, hello! I've done it twice and it's fairly easy. Remove the radiator fan the ETM to intercooler pipe, the boost pipe and then it's 4 x 10mm bolts from unde the ETM holding it in. Take them out but be careful not to let the unit drop as it's weighty (not heavy though). Also undo the electrical connector and you may have to take off a retaining plate holding the wire back that stops it moving around, this is usually near the bottom of the engine in the middle.
    Regards
    James
  3. The Following User Says Thank You to JamesT5 For This Useful Post:
    hillsidesteve (Tuesday 21st May 2013)
  4. #3
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by hillsidesteve View Post
    By the way, mine has just started the erratic idle today (see my post), and in my case it's a new ETM as the butterfly plate has been cleaned by me twice in 12 months and it was never that dirty. Be prepared to replace the ETM if necessary.
  5. The Following User Says Thank You to JamesT5 For This Useful Post:
  6. #4
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Cleaning the ETM only hides the problem really. It's the internals of the ETM that's failing.
    I was thinking about James' problem just now and remembered...
    ...There's a guy on fleabay that retrofits the marelli ETMs with hardware that won't fail, essentially making it work like the Bosch unit.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  7. The Following User Says Thank You to M-R-P For This Useful Post:
  8. #5
    Dec 2012
    BRISTOL
    73
    Ah so is it better to just replace it rather than waste time cleaning it then? Is mine likely to be a Marelli unit rather than Bosch? I'll try looking for this guy and replace it now I think, looks to be the best way forward.
    Thanks for the tip Martin!
  9. #6
    Dec 2012
    BRISTOL
    73
    Quote Originally Posted by JamesT5 View Post
    Thanks James, ref Martins reply, I think I will replace it now rather than waste time on it again. As you are probably going to do the same, soon we will both be idling happily for ever more
  10. #7
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    If you can chuck me some petrol money I'll come and fit it one for you when you get it unless of course you'd prefer to do it yourself.
  11. #8
    Jul 2011
    Poole, Dorset
    6,548
    By all means, try cleaning it. If its not been cleaned before, it will make a difference - how much difference and for how long is anybody's guess.
    310.2bhp / 333ft/lb
    SOLD
  12. #9
    "Need More Power
    Captain"
    c70geoff's Avatar
    Jul 2012
    Pontypool, South Wales
    651
    cleaned mine and running ok now
    C70 2.4 T Saffy Pearl now dead and stripped
    850 T5 "the Turk" wagon
    V70 D5 parked up for sale
    V50 1.8s family wagon
  13. #10
    Dec 2012
    BRISTOL
    73
    Well I decided to get the unit off today with the intention of cleaning it so a friend called round to help and it was off in 20mins.
    Surprised to find it was actually very clean with no carbon - possibly due to cleaner running LPG? - so rather than waste any time decided to send it off to VolvoDiagnostic for a full recon and upgrade to contactless. Called them first to discuss,it is now on its way via Royal Mail Special Delivery guaranteed to be there Friday morning.Should have it back by next Weds they say, just got to hope this solves the idling problem, we'll see.....
    Since I can't drive it for a few days I thought I might get a few other things done weather permitting - report and photos to follow over the weekend hopefully....
  14. #11
    Jul 2011
    Poole, Dorset
    6,548
    PCV? clean stuff? clean inlet manifold? c'mon dude, don't stop with the foreplay!
    310.2bhp / 333ft/lb
    SOLD
  15. #12
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by c70geoff View Post
    Looks like I've started a trend with the signatures then!
  16. The Following User Says Thank You to JamesT5 For This Useful Post:
    c70geoff (Friday 22nd November 2013)
  17. #13
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Yup.....tight arses till payday lol
  18. #14
    V70 R ish
    thewatsonsmouts's Avatar
    Feb 2013
    6
    dont send it to BBA Reman they screwed mine up big time had to buy a new one
    Ben Watson
  19. #15
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    A good video here, although it is pitched at selling the Xemodex item...
    http://xemodex.com/technologyimproved/video-8644347
  20. The Following User Says Thank You to jamesy12345 For This Useful Post:
    silverback02 (Friday 22nd November 2013)
  21. #16
    May 2010
    Bangor Co Down
    45
    Jamesy, / Anybody !!!
    My mates 2001, V70 T5, has been having accelerator problems, in that IF he slowly revs up, No problem car goes.
    IF he revs up to 3/4 throttle, again NP car accelerates . BUT if he tries harder, and puts his foot down, Then the engine just dies, until he lifts his boot a little and slowly builds it up.
    Would that be the ETM, or BAD spots on the Accelerator Pedal bits?
    any ideas plz peeps ?
    cheers.
