Results 1 to 13 of 13
Thread: will these fit
    Junior Member
    Jan 2013
    stockport
    3
    will these fit
    can anyone advise me on wheels to fit my 940 ? someone has told me late mondeo wheels will fit with the centres opened up is this true or should I stop getting my car advice from the local pub ?
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Yep your pub gossip sounds OK for once, speak to T5Steve. His 850 has been running Mondeo wheels for a while.
    Current Garage:
    *Data Sept 2013
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    I thought a 940 had a different pcd to the 850/70 series?
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Biff View Post
    different offset
  5. #5
    this member hass no status
    thunderace's Avatar
    Jun 2005
    Doncaster
    31
    850 - pcd 5x108, et 35-40, bore 65mm
    940 - 5x108, 18-22, 65
    960 - 5x108, 35-40, 65
    mondeo - 5x108, 35-42, 63.3
  6. #6
    Junior Member
    Jan 2013
    stockport
    3
    thanks for the info. just one thing whats et ??
  7. #7
    thunderace's Avatar
    Jun 2005
    Doncaster
    31
    ET is german for insertion depth, ie offset.
  8. #8
    Junior Member
    Jan 2013
    stockport
    3
    I've just been reading up on wheel et and its a bit confusing . am I right thinking I will need a wheel spacer of about 15- 20mm or am I being an idiot and completely misunderstanding wheel et ? if I am I suppose I could always ask down at the pub LOL
  9. #9
    under the bonnet
    redbaron's Avatar
    Nov 2008
    N.I.
    5
    no, you are right, you'll need spacers. Please buy hubcentric ones as the 20mm piece of steel with longer bolts idea doesn't work on a car the weight of a 940
    945 - being fettled
    nissan cube -
  10. #10
    Junior Member
    Jan 2013
    stockport
    3
    sorry another silly question . whats hubcentric ?
  11. #11
    HAPPY DAYS
    Jan 2012
    Stourbridge
    83
    Basically the spacer sits on the existing hub like your wheel would, then the spacer has another hub onto which the wheel sits.....if that makes sense!
    The larger spacers (20-25mm) can have an extra bolt set, so you bolt the spacer to the hub, then bolt the wheel to the spacer....again, if that makes sense?!
    WHY DOESN'T MY SIGNATURE WORK??? ...IT DOES NOW! :-)
  12. #12
    Junior Member
    Jan 2013
    stockport
    3
    yes that make a lot of sense . less stress on the wheel nuts and better location of the wheel. where would I get my hand on a set of spacers ? thanks for the advice
  13. #13
    Junior Member
    May 2012
    Halesowen
    1
    Mondeo rims will fit PCD-wise.
    The centre bore I believe is smaller (63.4mm opposed to 65.1mm I think), so will need opening out.
    Offset is too high on Mondeo (same as 850/V70/etc) - around 43mm. 940's need around 20-25mm. I'm using H&R DRM Hubcentric spacers on mine with Titans (850R wheels).
    I have heard of people using Mondeo steels, and cutting the centre out, and flipping it round and re-welding it. So, essentially using the wheel backwards with the centre turned the right way so the nuts still locate. I am not recommending this way, as you would need to get things very straight and have confidence in your welding!!
    Current: 1990 Volvo 760 GLE D24TIC ZF22 - 16psi, more fuel, Monark 293 nozzles, 40mm lower, Bilstein TCs, 22/19 ARBs, H&R DRM spacers, 17" Titans. Running Veg oil/petrol mix.
