That's exactly what mine sounded like. All these videos are making me want to go outside and fit an open cone filter on mine lol
^+1 going to put mine back on this weekend!
cut n blow dry,perms,and tinting prices on request!
I put a pipercross enclosed filter on the vovlo the other day and that doesa little chatter (tsshh noise) I'll get ordering a blanking plate now for it, only putting a dump valve on because it was a cheap ebay win.
Yeah my car is a Pre me7
right, fitted boost gauge, i split the pipe thats on the recirc valve, says im getting 6-8 psi which is about right for these engine?
i've recieved my blanking plate today, the pipe thats on the recirc vavle, where does that go to if im blaking off the recirc and not fitting my DV?
You run the pipe from the top of bov to the inlet manifold or vacuum tree
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Rudeyboy18 (Friday 12th April 2013)
I thought i didnt have a Vac tree since mine is a preME7? I can soon Block the pipe off that i've split and put the gauge onto another pipe
The vac tree is underneath the Black plastic cover covering the accelerator cable etc. Your vac tree will have 5 inlets, probably with all 5 capped off like mine was.
fitted the blanking plate, only took 20mins or so, so where should i run the gauge from then?
sorted! Put it on the vac tree before i went for a test drive in it, works spot on now! Cheers
yeah I put my DV on and it started loosing boost and ideling wasnt right ( I put the pipe form the reciec valve ontop of the DV as it says, but the boost kept coming and going, so I've took it off for now, Shame because i quite like the noise.
Oh and Frankie, the gauge is reading 6psi
