I'm starting to get quite concerned with my driveshaft and transmission and as of yet, I've not had the opportunity to take the car to a specialist for a proper evaluation, something I intend to do as soon as possible after pay day next week!
At the moment, 2nd, 3rd and 4th gears are really noisey, especially when accelerating making a gargling/grinding sound. There's also a whistle or whine as I declutch at times in those middle gears and a constant 'humming' at lower revs and if I free wheel the car with the clutch down or the car in neutral. This humming also takes place in 5th gear where there is hardly any 'grinding' noise at all. 1st gear is also not too bad although I'm starting to hear some noise there too.
But what's most concerning is I'm getting a 'squeak' in both directions when I'm turning the car in a car park or manoeuvring for example. The best way I can describe it is that its like someone is wearing leather trousers on a leather seat and their trousers squeal against the seat.
My theory is the noise from the transmission is being caused by a worn driveshaft bearing, because this humming when the car is free wheeling means the weight of the car is causing load on the driveshaft and this is why there is noise in neutral.
Additionally, if you think about the logic of it, the gargling/grinding takes place unde acceleration because the transmission is transferring power to the driveshaft during this time and this is causing the bearings to grind together. The squeaking when I'm turning around etc, is either caused by the driveshaft sitting out of position and therefore making this sound or something has 'dried out', it may also account for why the car seems to want to stray off towards the left despite a 4 wheel alignment on a calibrated laser alignment system recently.
Something isn't right here somehow!
Regards
James
