Results 1 to 14 of 14
    V70 R ish
    thewatsonsmouts's Avatar
    Feb 2013
    6
    1998 v70 AWD 2345 t wastegate acuator settings B5234t
    I seem to have a boost pressure problem, its driving me mad coz i used to get 12psi 1.2 bar of boost and now i cant. Tryed resetting actuator adjustment to 4.5 psi like i was told to by HLM as it has been remapped there with no success it spikes at 8.5psi at that setting so i tryed putting back to stock adjustment according to engine code 1.8psi and it boosts to 1 bar but dont seem as quick but only spiked at 1 bar for a second then dropped bit gutted really coz it was orsum before an now its not. i have no leaks, splits in pipes. boost control valve? dunno can anyone help pls ? shall i increase the setting to 3 psi?
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Have you been back to see Hamish yet?
    Volvo ABS ECU Repair
    V70 R ish
    Feb 2013
    6
    No he said all T5s are 4.5psi to set wouldnt let me question him coz hed been working on Volvos for 27 yrs
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Would this be a map that you inherited when you bought the car?
  5. #5
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    12psi is not 1.2 bar its 0.85 bar roughly
  6. #6
    nobananas's Avatar
    Feb 2005
    201
    Didn't think they made a V70 T5 awd.
    Modifications: Nowt.....yet !
    Daily driver: 855 R in Black,
  7. #7
    Member
    kim's Avatar
    Nov 2010
    Beaconsfield Bucks
    25
    I have a adjustable actuator fitted with 0.5 bar spring (7.2psi) 16t preload on rod Just 1 full turn .The actuator came fitted with the 0.3 bar spring (4.35 psi ) but that felt weak so upped to 0.5 bar. Now running 12psi mapped boost , no problems.
    They do others but this is mine ,took 4 days to deliver http://www.ebay.co.uk/itm/Kinugawa-A...item1c26563733
    Picture in situ . used a couple of washers to give more adjustment range
    Sits pretty don't she
  8. #8
    V70 R ish
    Feb 2013
    6
    The Wastegate mystery
    No Hammish at HLM remapped my car about a yr ago mate, Ive set it to 1.8psi with a mini vac seems to go well but turbo gauge still only spikes to 1 bar not 1.2 like it used too perhaps some fine adjustment might help ?
    Last edited by thewatsonsmouts; Monday 8th April 2013 at 21:16. Reason: hadnt included everything
  9. #9
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by kim View Post
    Looks good, so does the car, My actuator is getting weak so may get the same
  10. #10
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by T5frankie View Post
    Like the new sig pic mate, she is looking nice and RED now well done
  11. #11
    V70 R ish
    Feb 2013
    6
    I set the actuator to 1.8psi pressure, didnt seem right and would only pull 0.8 bar, i wound it out half a turn and it spiked more at 0.9 bar but dropped out really quickly so i turned it back to what it was and left it........ But wasnt satisfied so i turned it in half a turn and it pulled a bar today should i leave it or should i try for more? Dont wanna thro the crank like. But it looked like the whole in the actuator rod was half way over the wastegate pin does that ring anybells? thankyou all for you kind advice!!!!!!!!!
  12. #12
    Member
    kim's Avatar
    Nov 2010
    Beaconsfield Bucks
    25
    Quote Originally Posted by thewatsonsmouts View Post
    Hi I do not understand what you mean by setting the actuator...do you mean the pre-load setting ? I do not think you should mess with the preload too much. There is a lot of views on pre load ..here's one to get you started I decided to dump the old actuator from my T16 and put a new adjustable one on, after paying for the turbo then to have it rebuilt ..seems silly to be farting about with a spring strength you have no real idea of ?
    I have a LPT 2.5lit and as I am mapped to boost to 12psi ,I have been careful and preloaded just 1 full turn ,I might risk some more after a Dyno. But as it stands I do not get fuel cut off throw EMLs even when the wheels are screeching and the boost gauge is at 0.8/.9 bar's and mines an auto go go go.
  13. #13
    Member
    kim's Avatar
    Nov 2010
    Beaconsfield Bucks
    25
    If you are looking for answers to mapping go to these guys... other mapping dealers do when they have a problem
  14. #14
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    As an original map from HLM - if you have an issue then go see Hamish?
