M66 (S60R AWD)
FDR = 3.77:1
1st = 3.38:1
2nd = 2.05:1
3rd = 1.43:1
4th = 1.08:1
5th = 0.86:1
6th = 0.70:1
top speed = 182mph
M66W (T-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.27:1
4th = 0.95:1
5th = 0.78:1
6th = 0.65:1
top speed = 185mph
M66D (D-5)
FDR = 4.00:1
1st = 3.39:1
2nd = 1.91:1
3rd = 1.19:1
4th = 0.84:1
5th = 0.65:1
6th = 0.54:1
top speed = 223mph
Found this in my book
[IMG][/IMG]
I have an M66 T5 fitted and working with mine now, Tim Williams did it all for me but he did have to make a custom linkage to make it work correctly!
I Reckon I am Perilously close to 592 Bhp With all my non dangerous Mods
Dangerous Dave (Monday 18th March 2013)
I bet the d5 box would be good for mpg, but i also guess it would be too long for a t5.
I take it the M66w and M66D are the same box just different ratios, and the d5 box would fit?
what cars were the M66w fitted to?
I love the 6 speed box in my v50 t5 same as the focus 70 mph = 2400 rpm so better mpg, plus when you have had 6 gears going back to a 5 is like going back to a 4 your always looking for the extra gear that's not there!
2004 V50 T5 SE
As the sun was shining I set the spare sub frame, bolted on the engine block,head and turbo then the 6 speed gearbox.
Will have make a custom rear gearbox mount as they isn`t much space between the turbo,gearbox and the rubber mount
Apart from the rear mount the gearbox fits
What's different about the rear mount?
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
The M56 will not fit on the M66 box, and the M66 mount will not fit under the turbo
claymore (Sunday 31st March 2013)
How are you going to get around the reverse gate problem?
Volvo ABS ECU Repair
To engage the reverse gear (up & far left) on the 6 speed manual you have to push the lever down before you can get it. It sits adjacent to 1st.
That gate protection is on the stick/selector AFAIK. Without it I am fairly sure you can select reverse whilst moving forward (unlikely) or more likely select reverse, when setting off.
Must be different to the one on my diesel s40 then. I thought they were all
R 1 3 5
_ 2 4 6
not that I was trying to throw a spanner in the works, just more of a heads up.
The R has the same layout as Rob's, i.e. with reverse next to 6th
Yeah the 2.0d and t5 use a different pattern
2004 V50 T5 SE
