Results 1 to 14 of 14
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    removing handbrake cable
    i need to remove the handbrake cable from the rear hub assembly so i can take it off, tbh i've not even looked in the Heinz manual so no idea how it undoes or anything. Help please
    many thanks
    woody's Avatar
    Nov 2004
    Melton Mowbray
    109
    I think I just used shear force!
    Owned since 2002. '96 Green 855-R, Manual M56H conversion by Russ @ RT Mech, 82mm rebore, THS Rods, Wiseco Piston kit, Decked Block, Machine work was completed by: www.mandjltd.co.uk, Refurbed head inc skim & 8 new valves, ME7 Ex Manifold, RICA304, Forge Blanking plate, 302mm set-up, PowerFlex Top & Bottom, Front Strut Brace, Miltek Cat-Back, R.I.P, IPD Cone Filter.
    Latest update: 10000 miles as at 19/05/13.
    To do: Lots (but don't tell Mrs Woody!)
  3. The Following User Says Thank You to woody For This Useful Post:
    p fandango (Monday 25th February 2013)
  4. #3
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    You'll figure it out. I think it'll just unhook and unclip easily. Wind off inside the car first.
    Current Garage:
    *Data Sept 2013
  5. The Following User Says Thank You to JUDGENINJA For This Useful Post:
  6. #4
    JT's Avatar
    Jun 2010
    sussex
    1,641
    what are you up to now??? lol
    your supposed to be finishing the car, not taking more bits off??????
  7. The Following User Says Thank You to JT For This Useful Post:
  8. #5
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by JT View Post
    Bloody camber plates, I've got to grind off the bolt heads so need to take the assembly off to get the remaining studs took out
  9. #6
    JT's Avatar
    Jun 2010
    sussex
    1,641
    Quote Originally Posted by p fandango View Post
    bloody camber plates, i've got to grind off the bolt heads so need to take the assembly off to get the remaining studs took out
    doh!!
  10. #7
    p fandango's Avatar
    Aug 2004
    4,216
    now i'm assuming that the cables attached to this mechanisms somehow, anyone any details how, where & how to disconnect it lol
  11. #8
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Come on pedro use the angle grinder
  12. The Following User Says Thank You to t5 pete For This Useful Post:
  13. #9
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by t5 pete View Post
    i've already got no foot brakes so relying on the handbrake to stop me at the minute (think that might be an MOT failure tho lol)
  14. #10
    nobananas's Avatar
    Feb 2005
    201
    Haven't done one for a long time but I think you back the in car adjuster right off (so the cables are really slack) then remove the bottom tension spring on the shoes, spread out the shoes so you can unhook the mechanism then swing out the bottom lever and pull the whole mechanism out away from the shoes and it should expose the nipple on the end of the handbrake cable that you can then disengage from the mechanism....I could be completely wrong though !
    Modifications: Nowt.....yet !
    Daily driver: 855 R in Black,
  15. The Following User Says Thank You to nobananas For This Useful Post:
  16. #11
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by nobananas View Post
    i'll give it ago & let you know
  17. #12
    p fandango's Avatar
    Aug 2004
    4,216
    you were correct sir, i did cheat & just unbolted the handbrake lever to remove the cables instead of slackening the adjuster
  18. #13
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    If this job takes you all day Duane, remember to take a brake.... ahem, I mean a break!
  19. #14
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by JamesT5 View Post
    HELP, that was terrible lol
