Does anyone know the part required?
I have ordered Brembo pads and Disks but now need the handbrake shoes
S60 D5, 2002
BMW 545i touring
They are the same for all engines V and S models.Part number depends on where u getting them from.
I've read over on VOC that if you're changing the handbrake shoes, you may as well fit a replacement adjuster. Most have the H bar fitted:
which can be replaced by the 'claw' type adjuster:
The benefit for fitting the new adjuster is that the handbrake shoes can now be adjusted through a wheel stud hole for convenience.
Volvo Part numbers are 30793438 for the 'claw' and 30793437 for the 'adjusting link'. I've read that they cost approx £23 delivered from Simon at FRF Volvo.
I should imagine that this will be applicable to most if not all P2's - maybe worth looking into to....
Steve
spring 14 in that picture is different on the R only - it's longer.
R the shoes different on the 'R' cars phase 2 ,as mine need looking at,is it just the spring that different.
http://www.ipdusa.com/products/9579/...t-p2-s60r-v70r
Do Volvo do this kit ?.
I have a set of shoes and springs to sell - if you are still looking.
Alastair
Thanks but I Got a set of shoes from Volvo and the springs but reading this not sure if I have the correct longer spring as the dealer had them and if the 'R' are different seams to good to be true.
I think I will get the adjusters at the same time. But is there a spring/latch that holds the adjuster in place to stop it Turning when it's set.
If you just want the R springs then let me know the part number and I will check if they are the ones I have here.
Alastair
