I have been told normal oil consumption for the 850 t5 is .4l per 625 miles. Correct?
It doesn`t really matter what you have been told as all engines are different as are drivers!
I have only put one cupfull in my V70 T5 with a remap in a year.
It depends how much the motor is tuned or boost you have and how you drive it, thrash it, rev. it, drive it harder when cold ,it all determines how much oil you use and especially what oil you use.
my t5 does not use any oil at all i dont no why your is
RICA ECU Upgrade 16T Turbocharger OMP front strut brace mbc and pipercross Panel Filters 6000k hid kit dump valve running 275bhp volvo all the way...
Oh, i havent bought it yet. Thats what the guy who owns it has said. Thats an official figure, apparantly. Perhaps it does use some oil, although im told it doesnt smoke on boost or the over run.
Mine uses about that much which does concern me a little, however there is no blue smoke coming from the exhaust as a duff valve stem seal indicator. But I've been told it's not irregular for high mileage 5 cylinders to use this much oil too.
I had a engine which used around 400ml at around 3,000 miles. I took the head off and ported n polished it, replacing the stem seals at the same time. Now the engine doesnt use any oil at all. mileage is 125,000
There was no smoke on start up or over run,
Mine hardly uses any oil, but one do low mileage
Mine used 4ltrs in 70 miles yesterday
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
MoleT-5R (Friday 4th October 2013)
Make sure you drive it, start it from cold, and look for puffs of smoke and heavy breathing after a good thrashing. Check for wet stains on the outside of teh engine and UNDERNEATH!!! get it up on ramps if poss and crawl udner with a torch. Lots of oil probs are simply fixed on these cars, but some coiuld be expensive. Good luck
OK - cheers - that was done on a recent servcce and a LOT of the oil is coming off the front of teh engine, but not above the inlet manf and prob not the head gasket either.
I think I have multoiple probs. For sure cleaning the breather and fitting new pipes helped a lot in terms of smoke out the rear, but I fear turbo oil seals, valve stem seals and quite possibly worn bores, allthough the compression readings seem OK.
Big list of jobbies anyway :>(
I wouldsay to the origininal thread that any measurable oil loss in 1000 miles seems excessive. I think mine did not used to need a top up between oil changes except after some serious hard driving.
