Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    pcv info required
    What are symptoms of a blocked pcv system? Also how do i diagnose it. Thanks
    It's a 5 Cylinder Orchestra!
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Normally smoking from the dip sitck
    jdavis's Avatar
    Dec 2008
    1,050
    not got that but got a whistling noise which I've heard can be down to a blocked pcv system.
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Take it for a run til it's warmed right up, pull over and with the engine running, pull the dipstick. If it chuffs white smoke, then the pcv is blocked.
    I've not heard of a pcv causing a whistling noise, perforated vac hose, cheap MBC or a hole in the intake hose from the airbox to the turbo can cause whistling. As can a leak in the big boost hoses.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  5. #5
    Junior Member
    Jan 2013
    Widnes
    8
    How much white smoke are we talking about? And is it an expensive fix?
  6. #6
    Jul 2011
    Poole, Dorset
    6,548
    Basically, any smoke is a bad sign. The more smoke there is, the worse the blockage is.
    Luckily, on P2 cars, there's a banjo bolt that blocks before anything else (usually).
    I would check that first, it's a pig to get at but could save you the 100 odd quid on new pcv pipework.
    310.2bhp / 333ft/lb
    SOLD
  7. The Following User Says Thank You to M-R-P For This Useful Post:
    mikey32shaw (Wednesday 23rd January 2013)
  8. #7
    Junior Member
    Jan 2013
    Widnes
    8
    ^^^^^^ why dont you move to a house near mine :-)
  9. #8
    jdavis's Avatar
    Dec 2008
    1,050
    Martin can you give me more details on this banjo bolt please. Gonna take it for a run tomorrow and check dipstick.
  10. #9
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Have a look near the alternator on the underside of the inlet manifold,its a banjo bolt bit of a pig to get out also if you do remove it don't move the pipe around as it will have gone brittle with age and can snap off.
  11. #10
    Jul 2011
    Poole, Dorset
    6,548
    I'll try linking a thread of mine when I get on the pc. It's called "pcv help needed" one of my earlier threads. There's a few handy pictures.
    310.2bhp / 333ft/lb
    SOLD
  12. The Following 2 Users Say Thank You to M-R-P For This Useful Post:
    jdavis (Thursday 24th January 2013),silverhorse (Monday 28th January 2013)
  13. #11
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Is it the same on an R Harvey?
  14. #12
    Jul 2011
    Poole, Dorset
    6,548
    Yes mate.
    Below is the union disconnected and wedged so I could get some carb cleaner in it.
    This is the bolt that blocks.
    310.2bhp / 333ft/lb
    SOLD
  15. The Following 2 Users Say Thank You to M-R-P For This Useful Post:
    Biff (Monday 28th January 2013),jdavis (Monday 28th January 2013)
  16. #13
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    How does it get blocked Martin? Surely if the bolt is tightened, the hole is closed. I must be missing something. I will have a look at this in the near future as a matter of course. Might 'get it' when I see it.
  17. #14
    Jul 2011
    Poole, Dorset
    6,548
    There's a hole down the length of the bolt that meets the holes you can see. It's only about 2.5mm and gets blocked with hardened oily gunk. This bolt collects pressure from the manifold to aid ventilation. When my dipstick was smoking this was the only blockage in the system.
    310.2bhp / 333ft/lb
    SOLD
  18. The Following 4 Users Say Thank You to M-R-P For This Useful Post:
    Biff (Monday 28th January 2013),jdavis (Monday 28th January 2013),LeeT5 (Monday 28th January 2013),silverhorse (Monday 28th January 2013)
  19. #15
    jdavis's Avatar
    Dec 2008
    1,050
    Thanks Martin. Pulled dipstick other day. No smoke or anything.
  20. The Following User Says Thank You to jdavis For This Useful Post:
    M-R-P (Monday 28th January 2013)
  21. #16
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    How accessible it the union? What needs to be removed?
  22. #17
    Jul 2011
    Poole, Dorset
    6,548
    Not sure if the R is different, as it has 2 intercoolers doesn't it? I had to take the rad fan and housing off and it's a real pig to get at. IIRC, it's a 19mm bolt and I could only get enough of a turn on it with a spanner to "crack" it, then I undid it by hand.
    I have sausage fingers and forearms like popeye so most people would probably find it less awkward. I would definitely recommend it to anybody with ME7 and a blocked PCV as mine was completely clear apart from this bolt. It may not be the bolt on some occasions but look at the agro it'll save if it is
    310.2bhp / 333ft/lb
    SOLD
  23. #18
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    They do have two intercoolers but i think its in a forwards direction not backwards, so clearance will be the same. The banjo bolt looks familiar from when i did the PCV on my Laser, but i cannot remember where it is on the car, on a P2 anyway.
    Any guidance in its location?
  24. #19
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by LeeT5 View Post
    Yes it is,I think I still have the old pipe in the Garage, will have a look if I do I will take some photos of it the it costs about £160 from volvo I could have got the pipe from any Pneumatics Dealer for a couple of pounds.
    It's just the little bit on the end that snaps off.
  25. #20
    Jul 2011
    Poole, Dorset
    6,548
    As you look at the engine from the front, on the underside of the main body of the inlet manifold, far left. It has a solid coolant pipe round it.
    310.2bhp / 333ft/lb
    SOLD
