Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: HID help
    Volvoless ;(
    HowHard's Avatar
    Dec 2012
    Northumberland
    112
    HID help
    Hey,
    So I'm planning to buy some HIDs for my P1 V70, I've never done this and just wanted to ask a few questions.
    Afaik, I should need H7's, can anyone confirm this?
    Canbus? Don't even know what it means but is my car canbus?
    Anything else I should maybe know about buying/fitting HID's to my P1 V70?
    Cheers,
    H
    deathrider311271's Avatar
    Apr 2011
    Grimsby
    483
    Quote Originally Posted by HowHard View Post
    Hey,
    Afaik, I should need H7's, can anyone confirm this? Correct altho if your using standard headlampd get H7R bulbs
    Canbus? Don't even know what it means but is my car canbus? No canbus on the P1 cars
    Cheers,
    H
    answers in bold above
    P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
    Previous: 2004 XC90 T6, 240GLT Estate, 343DL
    Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
  3. The Following User Says Thank You to deathrider311271 For This Useful Post:
    HowHard (Sunday 20th January 2013)
  4. #3
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    You don't have a CANBUS system
    H7's sound right to me
  5. #4
    Old Fat Git with Grey Beard
    Need to prepare to do
    Santa-ing
    Santa's Avatar
    May 2010
    Frimley
    1,497
    Be really really careful, secure the ballasts well (I can show you a pic of one that had been dragging along the floor) and make sure no wire contacts come in contact with the body or yourself!
    Any suggestions, information, complaints or grievances relating to this forum please feel free to contact us, talk to a mod or administrator
    Cars : 2009 VW Passat CC 140 CR & 2015 VW Golf R. Uploaded Albums. Past Statuses (Or is that Stati?). Past Posts.
  6. The Following User Says Thank You to Santa For This Useful Post:
  7. #5
    Volvoless ;(
    HowHard's Avatar
    Dec 2012
    Northumberland
    112
    Quote Originally Posted by deathrider311271 View Post
    Cheers m8y! Sorry but what do you mean by if standard headlamps get H7R bulbs?
  8. #6
    Volvoless ;(
    HowHard's Avatar
    Dec 2012
    Northumberland
    112
    Quote Originally Posted by Santa View Post
    Awesome thanks, I'll make sure they're secure and try not to shock myself, definitely just saved me from letting them touch the body too
  9. #7
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    http://www.ebay.co.uk/itm/H7R-35w-UL...item5635123ed5
    H7R have an anti-glare shield for use in non-projector type headlights
  10. The Following 2 Users Say Thank You to Volvostorm For This Useful Post:
    deathrider311271 (Sunday 20th January 2013),HowHard (Sunday 20th January 2013)
  11. #8
    Volvoless ;(
    HowHard's Avatar
    Dec 2012
    Northumberland
    112
    nice1, thanks guys!
  12. #9
    Be safe and keep it in your
    pants!
    Nov 2012
    22
    Quote Originally Posted by Pault5estate View Post
    You sure? My phase 1 V70 threw a fault code up on my old HIDs til I got the canbus kit
  13. #10
    Mar 2010
    Bradford, West Yorkshire
    88
    Did you go with the canbus kit or not mate? I am about to do mine and I have a P1 V70 as well
    1997 V70 R
    Fully adjustable Koni's
    3" Jetex front to back
    Carbon Filter
    Black Comets
    Full tints all round
    The girls a stunner!
  14. #11
    Member
    Oct 2013
    Blackpool
    1
    The phase one x70 has bulb current drawn monitoring for the bulb failure indication, if the HID units you purchase draw less current than the standard bulb intended for the car you might get a bulb failure indication on the dash. I fitted HIDs in my 2000 phase one V70 with no issues so sometimes it simply works. H7 HID bulbs are for use in projector lens headlights (aftermarket addition to the car which is what I use) the H7R are intended for use with standard headlights that contain a reflector assembly needing the bulb in a specific location (the focal point of the reflector) BUT the lens of the headlight can still scatter the light if the front glass of the headlight has a beam focusing/ beam steering effect within it, plain clear glass lenses are a better option when you combine HIDs with standard headlights - Mike
  15. #12
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    the quick and cheap way round the bulb warning is to fit a 50w load resistor across the power cables to the ballast. you can then use the cheap 16quid eBay HIDs.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  16. #13
    Member
    Oct 2013
    Blackpool
    1
    The correct way to fit load resistors is to measure the current drawn by the HID kit then work out what that equates to in Watts (W=IxV) then deduct this value from that of a standard bulb (55W) you then calculate the actual resistive value needed to top the current drawn through the wire up to the original 55W value.
    Simply adding a 50W resistive load to the lighting circuit will overload the wiring as the HID kit could be drawing 35W in the first place - Mike
  17. #14
    Jul 2011
    Poole, Dorset
    6,548
    been fine for 18 months tho Mike and it's better than the 100w bulbs I had in there before
    310.2bhp / 333ft/lb
    SOLD
  18. #15
    Mar 2010
    88
    thanks guys. I am thinking of going with these? Any issues you envisage? Also, do i need to do anything about the full beam or is that part and parcel of the main lamp?
    http://www.ebay.co.uk/itm/2513573431...%3AMEBIDX%3AIT
    1997 V70 R
    Carbon Filter
    Black Comets
  19. #16
    Mar 2010
    88
    Also how do I tell if I have projection lens' fitted or not?
    1997 V70 R
    Carbon Filter
    Black Comets
  20. #17
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Spooky View Post
    Standard headlight on the left, projector on the right.
  21. #18
    Mar 2010
    88
    Ahhh right. Yeah defo standard on mine lol
    1997 V70 R
    Carbon Filter
    Black Comets
  22. #19
    Mar 2010
    88
    finally got round to doing this and fitted the main beam ones.... MUCH brighter!!!
    I am now doing the fog lights...what a pain in the arse this is LOL!
    Had to chop the lamp holders up to get them in.. which i managed to do first time just gotta sort the wiring out now in the morning. anyone ever done their fogs?
    If so where did you mount the ballasts?
    1997 V70 R
    Carbon Filter
    Black Comets
  23. #20
    Jul 2011
    Poole, Dorset
    6,548
    I screwed the ballasts to the horizontal plastic that reinforces the lower valence. (P2 V70)
    You need to make sure you stop any possible water ingress... One of mine went bang
    310.2bhp / 333ft/lb
    SOLD
  24. The Following User Says Thank You to M-R-P For This Useful Post:
    Spooky (Sunday 17th August 2014)
