Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 65
  1. #41
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The 2.4 has a 90mm stroke and the 2.5 has a 93.2mm stroke.
  2. #42
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by oblark View Post
    3mm as i said (ok i rounded down the 0.2mm lol), but doesn't that mean its a different block
  3. #43
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    It's either done on the crank or the con rods.
  4. #44
    p fandango's Avatar
    Aug 2004
    4,216
    the 3.2mm less stroke is done via the crank, but what i'm trying to say is it can't really be the same block as the piston moves 3.2mm less is it further away from the top at TDC than a S60R block. Who knows if they thickened the cylinder sleeves while they were losing the 3.2mm
  5. #45
    Jul 2008
    126
    bore is 83mm on the s60r and 81mm on the 2.4 IIRC.
  6. The Following 2 Users Say Thank You to Dream3r For This Useful Post:
    p fandango (Monday 21st January 2013),t5 pete (Monday 21st January 2013)
  7. #46
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Dream3r View Post
    ah just looked thru my engine list, & yes the B5244T5 has thinner bore & longer stroke
    B5244S 2435 83 90
    B5244S2 2435 83 90
    B5244S4 2435 83 90
    B5244S5 2435 83 90
    B5244S5 2435 83 90
    B5244T 2435 83 90
    B5244T 2435 83 90
    B5244T2 2435 83 90
    B5244T3 2435 83 90
    B5244T5 2401 81 93.2
  8. #47
    If in doubt thrash it and see
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    Quote Originally Posted by p fandango View Post
    the 3.2mm less stroke is done via the crank, but ...it can't really be the same block as the piston moves 3.2mm less is it further away from the top at TDC than a S60R block...
    Not sure if it is or it isn't but shorter stroke plus longer conrods COULD put the pistons at the same height at TDC. Just a thought...W
  9. The Following User Says Thank You to woz For This Useful Post:
  10. #48
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by woz View Post
    very good point, i've only ever heard of the 139mm or 147mm rods tho. Be certainly cheaper to lengthen the rods than make a different block
  11. #49
    This status has no user
    cherry1809's Avatar
    Jul 2008
    Miles from anyone
    1,816
    Quote Originally Posted by claymore View Post
    I have a s60 head on my new engine with the vvt deleted, solid lifters, ported and polishes and fernier adjustable camshafts on a 2.4 s60r bottom end.
    So a 2.5 R block (with the right mounts) with an 850 head would go in without too much bother?
    Current Chariots...
    Micra K11 'project sh*tbox'
    V70 D5 daily
    1991 Transit Recovery
  12. #50
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by cherry1809 View Post
    Yes
  13. #51
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    i am particularly liking the black pv544 with s60R/2.4T engine in this month's ppc magazine. took the owner 10 years to build but what a great job.
    the article might give you some tips about this question.
    oblark- are you sure about the 850 head onto a s60 r block? - i thought the r engine was the first on the narrower block , which is think from memory is either 40 or 20mm narrower.
  14. #52
    smithy's Avatar
    Apr 2006
    1,752
    Quote Originally Posted by partsforvolvos.com View Post
    The s60r block is not narrower that happened when ford wanted to put the engine in the focus and it was too wide.so they narrowed it for that car and then Volvo used it in the s40/v50 because that had a focus platform.
  15. The Following 2 Users Say Thank You to smithy For This Useful Post:
    cherry1809 (Tuesday 22nd January 2013),oblark (Tuesday 22nd January 2013)
  16. #53
    Trader
    Jun 2012
    270
    i stand corrected then , but the narrower block is also in the s60/v70/s80 i'm sure- its just the later version. when the s40II came out, they told us on the new model course it was done for crash zone space .
    maybe its from when the 2.4t became the 2.5t 2004 / 2005 ish?
    smithy - get back to your 900's lol
  17. The Following User Says Thank You to partsforvolvos.com For This Useful Post:
    WOODY T5 (Tuesday 22nd January 2013)
  18. #54
    cherry1809's Avatar
    Jul 2008
    Miles from anyone
    1,816
    Hope not, lol.
    Good timing on the thread starting up too... Lol.
    Having dalhousie's S60R engine off him for mine, as mines well and truely cattled now. Plan is, unless anyone pops up with a spanner for my works - Shim the 2.5R block (might even stick forged rods in while it's in bits) ported 850 head. Anything I don't know about that will stop this?
    I did ask Tim Williams and he said it's more hassle than it's worth.
    Current Chariots...
    V70 D5 daily
  19. #55
    Trader
    Jun 2012
    270
    Sounds good. Let's see who gets one together first.
  20. #56
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Hope not, lol.
    I would reconsider purchasing anything from Steve. Severe lack of morals, and would do anything and screw anyone over to make a few quid it would seem. I'm just downloading my small claims court forms as we speak...
    I wouldn't use the R 2.5 block anyway mate. Seems like a lot of work for no real gain, but if you want to go down that route, use the 2.4 from a late T5. In plentyful supply, and much cheaper. No need to fit liners and no need to fit forged rods either.
    Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T Turbo
    VXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" Downpipe
    Milltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
  21. The Following 2 Users Say Thank You to S70T5Chris For This Useful Post:
    cherry1809 (Wednesday 23rd January 2013),claymore (Tuesday 22nd January 2013)
  22. #57
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by S70T5Chris View Post
    Ohh, that's interesting, is there a thread somewhere?
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  23. #58
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    You mean like this
    PIC][/SIGPIC]
  24. #59
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Not currently.
  25. The Following User Says Thank You to S70T5Chris For This Useful Post:
  26. #60
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    so what year was that chris 2004 onwards??
