Sounds like the master clyinder could leaking past a seal back to tank.
Try to get it pressure bleed first.
Had a similar problem once before. Checked all the brakes, replaced master cylinder and bled brakes god knows how many times but the fault remained. In the end I stripped all the brakes and removed the anti-squeal shims which cured it. Found out that some of the shims were acting like a weak spring and slowly pushing the caliper pistons into the calipers very slightly. First press of the pedal would go to the floor and then it would be fine unless the brakes weren't used for ten minutes or so (like on the motorway) then you'd get a long travel again, not saying it's causing you're problem but it certainly caused mine !
Modifications: Nowt.....yet !
Daily driver: 855 R in Black,
Rather than just bleeding, have you completely changed your fluid?
Flexi pipes would be a good idea if they are the originals from new.
Never heard of shims making a lot of difference.
When I change my pads I do spend a bit of time cleaning and polishing the pins and sliders to ensure the pads can move freely.
then the last thing could be Master cylinder/servo.. It's been a while since I looked under my 850 bonnet are there any Vacuum lines that could be perished with a small air leak?
Current Garage:
*Data Sept 2013
As above you need to completely flush the fluid out of every pipe which will require quite abit of fluid, also you need to start with the furthest away.
*Update*
Right, I had the brakes bled and fitted new flexi hoses, result was a better pedal.....till today !
It's back to as it was, pedal travels a bit further down but not to the floor, if I release it and reapply pedal is great, lovely and firm.
The only other addition to my previous comments is that last time I drove the car, I was pushing along a bit and was using the brakes fairly hard (for me anyway).
Surely brakes don't need bleeding every 2 Months (I know they don't).
I'm now at a loss as to what to look at next, callipers (car doesn't pull under braking) or master cylinder, or could it be the servo ?
Any comments as always appreciated.
It's odd that a bleed cures it for a while. Maybe something's letting air into the system. There's definitely no fluid seeping from the master cylinder?
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
So u have brakes on the 2nd pump of pedal.If u do 2nd pump and hold it does the pedal go down slowly?
Weird...
310.2bhp / 333ft/lb
SOLD
Have you checked for brake fluid in the servo ? Easiest way is to pull the vac hose off and dip a cable tie into the bottom of the servo, any fluid and it's bye bye master cylinder. Another tip would be to clamp off each flexi pipe until the excessive travel stops though obviously this will only help if the fault is constant and you can't drive the vehicle like this.
I can see how a sticky caliper could cause that.
310.2bhp / 333ft/lb
SOLD
V70 Graham (Monday 11th March 2013)
To change the master cylinder is an easy job.When was your brake fluid changed last?Do a quick master cylinder change,don`t have to bleed the whole system,just the 2 pipes that go to abs unit by undoing them on the pump will do the job.All gonna take 30-40 min max.
