Originally Posted by
expolicev70t5
Well, got to the bottom of the lights problem, there is a little metal bracket that bolts to level sensor and rear arm, the bracket has coroded and snapped to the light senor arm had dropped down, looks like a blob of weld is needed to fix the bracket, I have Tie wrapped the bracket back to the rear arm on temporary basis and this seems to have resolved the light problem, as they are now realining them selves each time the ignition is switched on, just need to get it booked in now at local garage to get it fixed on permanent basis.
