Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    in dilema near ilford
    5seaterT5x2's Avatar
    Jul 2008
    Ilford Essex
    72
    Question solar battery charging
    Due to the fact i dont use the car much i usually have to mess about and jump start it ok can be done but just a pain in the $$$$ so am wondering about a solar charger can just leave it on car no worries about running cables etc. my question is how powerfull charger would i need? for instance would this do? or would i nneed more output? guess it's mainly the alarm that kills it?
    http://www.maplin.co.uk/solar-powere...-charger-98358
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Nice little unit I have one which I always use when cars left a airport car parks never had a problem starting the car even when it's been very cold for a couple of weeks,great idea i keep it in the boot all year round.
    Jul 2008
    Ilford Essex
    72
    ok thanks but do you mean you use one of these units? or something similar? more or less powerfull? thanks Gareth
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by 5seaterT5x2 View Post
    Yes got the same size unit.
  5. #5
    martybelfastt5's Avatar
    Jul 2008
    belfast
    760
    have to invest in one of these
    1995 854 t5r
  6. #6
    Jul 2008
    Ilford Essex
    72
    think i must have some kind of electrical fault battery was replaced last winter with a heavy duty version for the t5, but only lasts about a week tops even after a decent run, and solar panel dont seem able to keep it charged. i realise electrical can be lots of fun and how long is a piece of string lol but are there any regular known places where this might be ocurring? i'm guessing theres some kinds drain on battery somewheres am getting fed up with jump starting the flamin thing as io dont use the car that much ;-/
  7. #7
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Oblark had a problem with his 850 where the outside temp sensor shorted to earth and would take his battery down in 2 days. Worth a look.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  8. The Following 2 Users Say Thank You to M-R-P For This Useful Post:
    5seaterT5x2 (Monday 21st January 2013),oblark (Monday 22nd September 2014)
  9. #8
    Jul 2008
    Ilford Essex
    72
    oh right ok i'll look into that, just bin outside with torch to locate item seems easyish to get to and get out
  10. #9
    nobananas's Avatar
    Feb 2005
    201
    Just out of interest, the solar panel, is it connected to the battery or plugged into the ciggy lighter, if it's the latter it won't work if the ciggy lighter only works with the ignition on.
    Modifications: Nowt.....yet !
    Daily driver: 855 R in Black,
  11. The Following User Says Thank You to nobananas For This Useful Post:
  12. #10
    Jul 2008
    Ilford Essex
    72
    Quote Originally Posted by nobananas View Post
    straight to the battery
  13. #11
    Jul 2008
    Ilford Essex
    72
    but then again, surely if the digital temp gauge (as opposed to the coolant gauge) appears to be working surely the sensor should be ok? but think as it's so open to the elements i'll get amongst it at the first opportunity just to check
  14. #12
    Jul 2008
    Ilford Essex
    72
    ok well anyway have unplugged the little blighter and battery on charge outside me garage, we shall see ;-/
  15. #13
    Jul 2008
    Ilford Essex
    72
    guess its not the sensor? as it's unplugged and battery flat tonight $$$$ **
  16. #14
    Jul 2008
    Ilford Essex
    72
    can anybody tell me which fuse is for the outside temperature sensor please? it's not marked on fusebox lid. thanks gareth
  17. #15
    nobananas's Avatar
    Feb 2005
    201
    The way I usually check for a current draw is to get a multimeter which has a minimum of a 10 amp load capacity. Disconnect the positive batt terminal and connect the multimeter in series with the meter reading amps. If you can close the bonnet with the meter outside then that will be better then lock the car how you would normally. You will get a current spike when the central locking kicks in (but it's usually less then 10 amps so the meters fuse shouldn't pop) and it will take a few minutes till everything quietens down. As a general rule you shouldn't be seeing anything more then 0.5 of an amp (usually you would see far less). Anything more and something is drawing current when it shouldn't be. If you can open the bonnet (wedge down any alarm pin switches) and start pulling fuses one by one till the current reading drops off then it's just a case of tracing the faulty component on that fuseway.
  18. #16
    jotter22's Avatar
    Nov 2011
    Gravesend,Kent.
    167
    Is the unit waterproof or does it have to be inside the car?
    Tony.
  19. #17
    Jul 2008
    Ilford Essex
    72
    bumpety bump
  20. #18
    Jul 2008
    Ilford Essex
    72
    Quote Originally Posted by jotter22 View Post
    Tony.
    not sure but i just put mine on my dash and route the wire out passenger door and under bonnet
  21. #19
    Jul 2008
    Ilford Essex
    72
    just bought one of these nice compact little jobby, fits nice n snug under the bonnet with it shut. ideal for the bikes as well.
    http://www.argos.co.uk/static/Produc...er/7404881.htm
  22. #20
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    I have a solar panel charger that plugs directly into my EOBD socket inside the car. Just rest it on the dash and the flashing blue led tells you that its charging. Brilliant.
    Don't even have to open the boot to get to the battery, which is impossible without proper tools on a P2. Unit also has crocodile clips if you want to connect it directly to the battery.
    It cost me £24.
    Don't buy it off eBay else it will cost you £29. Just find an AA man and ask to buy it off him.
