Just done the front pads DIY. Bought Pagid from GSF. Fitting was a doddle, done loads before. Trouble is there is now just no "feel" to the brake pedal. The rears kick in before the fronts and only a determined shove with the right boot makes the car dip at the front. Standing on them will bring in the ABS at the front but in normal use they are just poor. Air lock in the system-bleed the system? Brakes do not cause the car to veer left or right and I refuse to believe I have knackered both pots doing the job. Thoughts?
Cheeers,
Ian
