Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 202
  1. #81
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The piston rings arrived from Germany but the gasket/o rings didn`t
    The main brg bolts where torqued up then the piston/rods where fitted
    Watch this space as more to follow tomorrow
  2. The Following 2 Users Say Thank You to oblark For This Useful Post:
    claymore (Saturday 18th January 2014),merc85 (Sunday 19th January 2014)
  3. #82
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by oblark View Post
    they look identical to ME7 short skirt pistons, what length rods you running?
  4. #83
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The pistons came from 2 x V40 T4 2.0 litre
    The rods are 139.5 m/m long
  5. #84
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Here is a short video of the rebuild so far.....
    And here is a preview of what the sngine will look like when finished...
  6. The Following 10 Users Say Thank You to oblark For This Useful Post:
    artfulflounder (Saturday 1st February 2014),Biff (Sunday 19th January 2014),cherry1809 (Monday 20th January 2014),claymore (Monday 20th January 2014),dant5r (Monday 20th January 2014),expolicev70t5 (Tuesday 21st January 2014),JUDGENINJA (Monday 20th January 2014),T5RPete (Thursday 13th February 2014),theflyingbrick (Sunday 26th January 2014),WOODY T5 (Sunday 19th January 2014)
  7. #85
    Trader
    Nov 2010
    chester le street
    969
    looking good. thought you might of went for a 3" down pipe
  8. #86
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by graemewelch View Post
    It is a 3" down pipe
  9. #87
    Trader
    Nov 2010
    chester le street
    969
    sorry my mistake. at first glance i thought it was a straight flange. just thought after all the effort thats been put in why would he restrict it with a 2.5" exhaust. ill look closer next time befor opening my mouth
  10. #88
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Liking the music off the video Rob, and the editing skills are coming on too
    Keep it up dude
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  11. #89
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Keep it up dude
    Wot he said, liking the video mate.
  12. #90
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Ooo, shiny, would look good in my C70.
  13. #91
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Nice bit of Rob Zombie!! Cool vid mate, keep it coming I say!
    Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T Turbo
    VXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" Downpipe
    Milltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
  14. #92
    Jul 2008
    2,869
    Good to see things kick started again, did (will) you hone the bores or is it all as removed?
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  15. #93
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    So is a new oil pump on the way as it's missing or just waiting for the gaskets set to turn up.
  16. #94
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    back by popular demard here is a update on the rebuild.
    The head was stripped down for the ports polished and to have valves cleaned and lapped in.
    It was then off to the dishwasher for a long hot wash ready for assembly today.
    New valve stem seals where fitted, I had to modify a valve spring compressor to get the valve springs out as they sit so far in the head.
    Timed up the N/A cams to inlet 2 degrees advance and exhaust 2 dgrees retard, turned the engine over gingerly through 2 revolution of the crank and all was ok
    Just need to get some seals for the turbo and a water pump then it`s finished
  17. The Following 5 Users Say Thank You to oblark For This Useful Post:
    AndysR (Sunday 26th January 2014),artfulflounder (Saturday 1st February 2014),claymore (Sunday 26th January 2014),M-R-P (Sunday 26th January 2014),theflyingbrick (Sunday 26th January 2014)
  18. #95
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Looks great buddy well done mate
  19. The Following User Says Thank You to merc85 For This Useful Post:
    oblark (Sunday 26th January 2014)
  20. #96
    JT's Avatar
    Jun 2010
    sussex
    1,641
    looks fantastic! nice work!
  21. The Following User Says Thank You to JT For This Useful Post:
  22. #97
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    That is looking fantastic Rob.
  23. The Following User Says Thank You to S70T5Chris For This Useful Post:
  24. #98
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Looking good mate, shouldn't be too long now before it's all done.
  25. The Following User Says Thank You to V70 Graham For This Useful Post:
  26. #99
    Feb 2006
    manchester
    628
    Very nice keep the good work up
  27. The Following User Says Thank You to abdul For This Useful Post:
  28. #100
    Jul 2011
    Poole, Dorset
    6,548
    Big shiny thingy
    It'll look great in a modified Honda 400-4 frame
    310.2bhp / 333ft/lb
    SOLD
