Got bored this afternoon so I took my old engine apart. The main and big end brgs look good with little wear.
But the bores do have some wear in them and they is signs of oil getting past the compression rings.
The max gap on the piston rings in the bore should be 0.20mm - 0.40mm and mine are 0.60mm so the bores are worn.
As the pistons are "D" piston the bores should be 81.01mm - 81.02mm
My question is this where can I get either 0.5mm or 1.0mm oversize piston and rings OR do I just fit new piston rings ??
