hi. as some know I fitted some fleabay after-market reverse sensors and all is fine with the fitment.
But after some time now I've noticed that they perform below par in terms of the 'beep' they emit. Sometimes it's a good solid loud beep - the kind you want.
But most of the time it's a feeble barely audible muffle which I have to struggle to hear - not ideal obviously.
I am assuming not enough power to the unit from the reverse bulb cable I am using.
So - couple of questions:
1) Is there an alternative reverse-switched 12v power I can grab from somewhere? Even if running a long wire?
2) With the fact I now have quite a bit of after-market electrics in my car (sensors, satnav, powered-RTI motor, new HU, 2x amps, etc.) could I be drawing "too much" power for the battery and need something more hefty? This is totally outside my knowledge zone so is really just a semi-educated guess.
Thanks in advance
H
