Results 1 to 17 of 17
    I might act crazy but i don't
    smoke crack
    Oct 2010
    Gravesend
    174
    Couple of questions about D5's
    As above really getting made redundant soon and as I'll only waste the money on crap anyway I might aswell replace my knackered v40.
    I've been looking at the V70 and S60 D5 but the reviews don't seem to be too great apart from the fuel economy, from what I've read they should have the cambelt and associated parts changed every 60k aswell as some electrical gremlins inc. the DIM playing up and various other bits and pieces.
    So my main question is should I get one? This would be the most expensive car I've bought (looking at spending about £3k) but I don't want to buy another car that I have to spend a fortune on every other month.
    Any advise would be welcomed
    Cheers
    Dave
    Currently driving a BMW 318 because it was cheap
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Ok, the DIM problem is only with cars up to the end of 2003, '04 cars are fine in that department. After (iirc) 2007, the engines are less eficient.
    So, go for a D5 between 2004 and 2006 with a recent cam belt and you'll be fine. My mate (Mr.D) has a 2002 V70 D5 and it's perfect apart from the mental central locking (can happen with any P2 car)
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  3. The Following User Says Thank You to M-R-P For This Useful Post:
    Dave86 (Wednesday 10th October 2012)
  4. #3
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    i bought mine May 2009, & not regretted it at all. Has had the DIM issue which my bro managed to sort(ish), & had to replace the intercooler which isn't a bad job to do yourself. As long as you give it a good test & look out for the signs you should be alright
  5. The Following User Says Thank You to p fandango For This Useful Post:
  6. #4
    p fandango's Avatar
    Aug 2004
    4,216
    what year did they introduce the DPF, i wouldn't touch a euro 4 engine
  7. #5
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by p fandango View Post
    Think it was '06-'07 mate. Happy to be corrected tho.
    310.2bhp / 333ft/lb
    SOLD
  8. The Following User Says Thank You to M-R-P For This Useful Post:
    p fandango (Wednesday 10th October 2012)
  9. #6
    smoke crack
    Oct 2010
    Gravesend
    174
    Cheers Martin at least I now know what years to look for.
    Most basic repairs I can do myself so it's not too bad, I just don't want to be doing it all the time lol.
    Also does the D5 have an electronic throttle as I really don't want to be going through all that again.
  10. #7
    Jul 2011
    Poole, Dorset
    6,548
    The electronic throttle problem, like the DIM was sorted for the models after 2003 mate. Never known of an issue with the throttle on a D5 at all. (different engine)
    310.2bhp / 333ft/lb
    SOLD
  11. The Following User Says Thank You to M-R-P For This Useful Post:
  12. #8
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Dave86 View Post
    believe me i spend hardly any time working on Bonny (my D5), tbh i've never even changed the oil yet. D5's have got an electric throttle, but don't think its done via the usual ETM which has the issues
  13. The Following User Says Thank You to p fandango For This Useful Post:
  14. #9
    smoke crack
    Oct 2010
    Gravesend
    174
    It's looking promising so far is there anything else I should look out for?
  15. #10
    Jul 2011
    Poole, Dorset
    6,548
    Flip the menu on the info screen and look at the average mpg. If it's under 35-39 ask when the mixer pipe was last done. If they say "I dunno" say it'll cost a few quid to get that sorted, knock some money off and do it yourself in 10 minutes with basic tools and a can of carb cleaner
    310.2bhp / 333ft/lb
    SOLD
  16. The Following User Says Thank You to M-R-P For This Useful Post:
  17. #11
    p fandango's Avatar
    Aug 2004
    4,216
    when you take one for a test drive, give it a good thrash (not just because it's not your car). If you get any vibrations higher up the rev-range then run away, the DMF needs changing
  18. The Following 2 Users Say Thank You to p fandango For This Useful Post:
    Dave86 (Wednesday 10th October 2012),M-R-P (Wednesday 10th October 2012)
  19. #12
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Good thing about d5s is that its a reliable engine, in the last 10years diesel engine have got more power but lost a lot of the reliability, but the d5 seems to be a stronger than most.
  20. The Following User Says Thank You to LiamT4 For This Useful Post:
  21. #13
    Nov 2006
    planet earth
    14
    Look for a face lift (usually has chrome trim in bumper corners) started coming in around 54 plate, and has the black wheely bin lid on engine (grey was the 185 less economical engine) only other things are as said service history for belt, and DMF failures, have check for top engine mount, and the gearbox tie underneath - both will be shot (unless replaced at some point) and are good haggling points - 3k should get you a 1/2 decent 54/05/55 plate, clean out on EGR pipe (decent write up on VOC) Mike (outnumbered) on various forums is the D5 Guru
  22. The Following User Says Thank You to cookie For This Useful Post:
    Dave86 (Thursday 11th October 2012)
  23. #14
    Moderator
    y2blade's Avatar
    Nov 2005
    The Shire
    1,197
    Has anyone mentioned the Clutch slave cylinder yet?
    Dave if you can get one that has already had the slave cylinder replaced that would be a bonus.
  24. The Following User Says Thank You to y2blade For This Useful Post:
  25. #15
    All work and no play makes
    Jack a dull boy
    Jul 2012
    North Yorkshire
    88
    Anything with over 130k or so on the clock will be getting ready for an intercooler and probably a slave cylinder, clutch and possibly flywheel.
    Mostly it`s the usual Turbo Diesel related borkage you`d get on any oil-burner at that sort of age, generally pretty good though.
    Heavy on suspension parts as well.
  26. The Following User Says Thank You to Fubar1977 For This Useful Post:
    Dave86 (Sunday 14th October 2012)
  27. #16
    Blueegh!
    MRTREE's Avatar
    Jan 2012
    Leeds
    25
    i bought one back in august an 03 S60 with all the trim 175k now at 179k , i love it and i havnt had any problems with it mine needs a service though and i think i will clean out the mixer pipe just to keep her on form, i would defo recomend one!
  28. The Following User Says Thank You to MRTREE For This Useful Post:
  29. #17
    smoke crack
    Oct 2010
    Gravesend
    174
    Cheers guys I'm torn between the S60 D5 and the Mercedes C270 CDI at the minute. Going to take a couple out for a test drive next week and see what I prefer.
