I have checked the fluid thats full (very dark tho) any ideas before changing the pump? sorry on my 850 t5 cd
I seam to remember a problem with the fluid frothing up in the tank which would make the pump noisy,a pipe or fitting would fall off inside the tank to cause a problem?.
bucky (Wednesday 10th October 2012)
that's something i cud look t its really whining even with a bit of lock on
Yeah, I remember that too. Drain the tank and get a torch and have a look...
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
ye man thanks pal do u no if theres a filter atall
I got the exact same on my 850 CD, it whines even when the steering isnt being turned but gets louder the more I turn the wheels, its seriously irritating, lemme know how u get on bud
'96 850 T5 CD Manual estate
2nd owner, 136,000 with a service history as thick as the bible
It's basically just a bit that falls off inside the tank. When it does, it causes foaming of the fluid. If it has fallen off, just retrieve it (it'll be rolling around in the bottom of the tank) and re attach it with some super glue or epoxy resin.
If you're feeling flush... replace the tank
310.2bhp / 333ft/lb
SOLD
ye a will do pal ppl seem to think sumets fell off inside the tank cheers pal
if i find anything al put it on tomorrow thanks lads
I've used this stuff before on my T5. It stopped the rack leaking and as soon as the stuff hit the reservoir a whining noise that I didn't even know I had suddenly stopped !. Well worth a go.
http://www.ebay.co.uk/itm/1Ltr-Lucas...item3a7a6aa8a3
Modifications: Nowt.....yet !
Daily driver: 855 R in Black,
ye me to pal
sorry mate a shud mention there is no leaks tho
its to much fun to break. will do when something major goes!
just gone to have a look at the reservoir and there isnt alot of fluid in now maybe it got blocked an unblocked its self. and is that a float in the tank does anybody no?
I used this on my `97 V70 T5 and the rack carried on leaking from the top seal, but it does say on an advert perhaps a second bottle may be needed!!
My pump was making a loud whine and so does it`s 2nd hand replacement with Lucas oil in it!!!!
It is the pump ,so where to now??
mine was doing something similar put some Lucas fluid in and sorted it,and before it was squealing and the rack was leaking slightly,fine now thou!!!
