The only thing he has changed is the first Lambda sensor and the car is now overfuelling, you can smell the petrol very strong through the exhaust??? but with no sensors been set off I can only guess mechanical
Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
Current Car:850t5
on my old 940 it was the AFM which then led to lambda failing.
Problem solved, new NGK Lambda was duff (Voltage tested) , replaced with a new Bosch sensor, took a few miles for the ECU to remove limp mode(2 psi of boost max). Lambda light still lit but will pull ECU out to try and re-set it. Thanks to Shep for reading my codes (even though he didnt find any) and while X-factor was on as well! Top bloke, and everyone else for your words of wisdom!!!!
T5frankie (Tuesday 9th October 2012)
