I have just had a read of this link and ok, so it is interesting but at the end of the day it doesn`t matter how much fluid is supposedly moved as it "doesn`t move does it"!!......if it moved then you would have a leak!
There is give in the pedal but when the system is bled properly so no air then the pedal is hard, the pads are damn nigh against the discs as when jacked up and you turn a wheel you can hear them touch, also after a couple of days of non use when first moving the car you can here the newly formed rust rubbing so all this about volume movement is not what it seems? Yes, there maybe more volume in the system due to larger calipers but the movement when the brakes are applied is minimal as you cannot compress hydraulic fluid.
Also as said in the link two larger piston`s in a caliper will give more pressure than a four pot caliper. You will only get better or more pressure if you do as said in the link and have a larger inside diameter master cylinder.
Same principal as gearing!
