Hello, its been a while since ive been on here so its good to say hello! hope all is well
Right i hope you can help or have something to say and apologies if this has been covered before
I recently fitted a remapped ecu to my 850 T5 as i used to run a MBC before, i had no problems before but i was looking for more power and i really wanted the ecu to have a say in what's going on safely using the stock solenoid again.
The problem im having is with the new ECU is the boost is very odd and doesn't want to hold, it will hit 16.5psi under load but it falls of as the revs climb to around 12 psi @ 5000rpm where it holds which is what i was running before with the MBC.
And most oddly if you give it the beans from 1st gear and go through the gears or boot it from higher revs it never goes above 12 psi no matter what even if you come off the pedal and reapply in any gear, although the boost is totally stable at 12psi while going through the gears. The only way to hit 16psi is if im in second or higher from lowish revs and it may hold for 1000rpm-1500rpm or so once its peaked and the difference in pull is huge!
Any ideas or thoughts???
The car runs a brand new turbo with a 16T compressor wheel, full de-catted exhaust, panel filter and before the remap i had it rolling roaded to check its health. it ran 240bhp and 253lb/sf of torque @ 12.5psi boost dropping to around 11psi @ the rev limit so no issues there and i was happy with the results. Im also now running on 97RON since the map for safety.
The boost piping and vac piping is all new as its just been replaced and with the turbo being new i cant see it being actuator related.....
do the stock recirculating valves leak @ higher boost/revs???? as this is my best guess as to why it wont hold boost, does anybody have the same issue?? i really would have thought it could have at least held 15psi through the revs surely ??
Its also worth me mentioning that i tried the MBC i ran before set at 16psi and it spikes to 16 and then just drops of rapidly to around 12 once again ;/
any comments would be greatly appreciated thanks in advance
here are a few recent pics of the car as its changed a little since my last visit
thanks, Jason
