Hi. Before I go an mess it up, does anyone have step by step pics of how to change a door please?
cheers
cheers
"Just for once, let me look at your Volvo with my own eyes."
This on a phase 2 Vader?
Front or rear?
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Think its the same as the 850, which is quite easy TBH
The wiring connector is easy to do, undo the small screw in the connector and twist the connector to unlock it and pull it away from the car body.
Pull the rubber boot away from the door check strap base and undo the torx bolt.
The two hinges have large grub screws in them, loosen them off and the door should then lift off the hinge pins.
You can see the door connector and hinge grub srews in this pic
vaderboyo (Monday 30th July 2012)
thats spot on cheers
its for the rear of my awd, think i have found some doors to swap over but was worried about alighments after replacement etc
this is really helpful cheers
Door arrived, not as good as I was hoping but at least its a perfect colour match and better than whats already on there.
Planning to change them over next week....if it stops raining lol
Dangerous Dave (Tuesday 25th September 2012)
