Hi,
I have a V50 T5 SE Sport (2006) with two fault codes that are driving me mad.
The 2 camshaft control solenoid valves are showing error codes:
ECM-611B and ECM-614B or P0026 and P0027, depending on what code reader is used.
The 2 VVT control solenoid valves are not functioning, resulting in a rough idle.
I'm finding it strange that both failed at the same time.
Toying with the idea it may be an electrical problem, rather than mechanical.
Read somewhere that a faulty battery could cause this, my battery has been playing up lately, if I leave the radio on (engine not running) for more than 15 mins, I get a low battery warning and then it shuts the radio off. Just a thought, but got lots of theories at the moment, just need a solution.
