Took the new toy out for a spin tonight and it wasn't too enjoyable as the dump valve seems to open at 3500rpm which obviously takes me off boost and just keeps venting air, any suggestions??
Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
Current Car:850t5
You got it piped the wrong way round???
Current Garage:
*Data Sept 2013
It seemed fine all the way home when I collected her
Current Car:850t5
take it out mate,mine used to do the same its the most annoying thing the car never seemed right so i took it out slapped a blanking plate on the turbo and not only did the car run better and smoother it sounds the dogs danglys failing that you need a stiffer spring in the dump valve
full respray..plenty of body mods..comets..ray cat back noise pipe..decat and wrapped downpipe..me7 exhaust manifold..3" throttle body with ported inlet manifold..blue injectors..adjustable fuel reg..reverse intercooler pipework..19t..open cone air filter..255 fuel pump..m-r-p short shift..boost gauge..unknown remap..adjustable suspension..lightweight crank pulley..n/a cams..stripped out interior..and a heavy right foot
Ok so if it piped in OK then something must have broken..??
Pipe snapped??
If it's a diaphragm one maybe it has popped...??
If its a piston one, maybe the spring has gone??
Current Garage:
*Data Sept 2013
shepbomb (Thursday 5th July 2012)
going to have a good luck tomorrow because we nearly got flooded earlier the rain was that bad, will keep all informed, and thanks for the advice judge
Current Car:850t5
