Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Boost problems.
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Boost problems.
    I took the R out last night for a quick blast to the supermarket, and I noticed that in 3rd and 4th gear especially, when I floored it, the turbo spooled up as normal, giving nice strong boost up to about 4000rpm, then hesitated, then boosted again, then hesitated again, then boosted again, it continued doing this all the way up to the redline. Does anyone know what the problem might be, it's as if the wastegate is opening and shutting repeatedly after about 4000 rpm so my thoughts are TCS, or actuator, but not sure. Any help would be appreciated.
    Oct 2009
    Milton Keynes
    35
    Check codes? It may show one of your sensors being off.
    2005 S60 T5 - Remapped 321BHP
  3. The Following User Says Thank You to MattM For This Useful Post:
    stribo (Friday 29th June 2012)
  4. #3
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by MattM View Post
    Will I be able to check them with a generic OBDII reader?
  5. #4
    This user has a status
    s_cowen's Avatar
    Nov 2011
    Northumberland
    38
    Mine done the exact same as yours the other week & I used a generic code reader & it showed up a stored code & was the IAT sensor even though the EML wasn't on, cleared the code & cars been fine since,
    My03 S60R, 340bhp Rica remap, Tinted windows, Stainless 2.5" cat back exhaust system, FMIC.
  6. The Following User Says Thank You to s_cowen For This Useful Post:
    stribo (Saturday 30th June 2012)
  7. #5
    Suspended
    Sep 2011
    Hampshire
    28
    Ive got a code reader
  8. The Following User Says Thank You to dalhousie2008 For This Useful Post:
  9. #6
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    O.k., cleared the code, and been out for a blast, it was fine at first, but then the problem returned. I got home, and plugged the reader back in, and the code has returned. The code is:
    P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
    but I'm none the wiser, is it a cam sensor, crank sensor, or something totally different. HELP
  10. #7
    Moderator
    happy
    shepbomb's Avatar
    Jun 2011
    Doncaster
    374
    P0017 -- ECM-671C -- Camshaft position, exhaust -- High, (I would guess a faulty camshaft position sensor)
    Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
    Current Car:850t5
  11. The Following User Says Thank You to shepbomb For This Useful Post:
  12. #8
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by s_cowen View Post
    Have you got yr own reader. Im after getting mine done.
  13. #9
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    cheap ebay bluetooth one and the torque app works fine for mine (not that ive had a single code since I got the DIM done )
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  14. #10
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by shepbomb View Post
    Does anyone know where this is, as the inlet sensor's in full view, but can't find the exhaust one.
  15. #11
    s_cowen's Avatar
    Nov 2011
    Northumberland
    38
    Quote Originally Posted by graemewelch View Post
    Yeh mate got a wifi obd cable which links up to my iPhone & I have a couple of apps which alow me to read & clear only the generic codes & also data log while you drive, I'm normally near Chester every day for work & always carry the cable on me, so if you ever need it give me a shout & can sort something out!
  16. #12
    Old Fat Git with Grey Beard
    Need to prepare to do
    Santa-ing
    Santa's Avatar
    May 2010
    Frimley
    1,497
    I have a feeling it will be under the engine bracket mount but hopefully someone can confirm that before you remove the bracket
    Any suggestions, information, complaints or grievances relating to this forum please feel free to contact us, talk to a mod or administrator
    Cars : 2009 VW Passat CC 140 CR & 2015 VW Golf R. Uploaded Albums. Past Statuses (Or is that Stati?). Past Posts.
  17. The Following User Says Thank You to Santa For This Useful Post:
    stribo (Sunday 1st July 2012)
  18. #13
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I think this is exhaust camshaft sensor.
  19. #14
    Trader
    Nov 2010
    chester le street
    969
    Im more towards durham now ( witton gilbert). But can always meet somewear yr passing. Ive just ordered a bluetooth device so hoping thatl work ok with my phone.
  20. #15
    Feb 2012
    135
    The correlation between the exhaust camshaft sprocket and crankshaft have gone out so far that the control module cannot adjust the adaption anymore so you get the code and should have the light on as well!
    You may need an oil change, cambelt jumped a cog, VVT valve on exhaust sprocket gone west. The ECM-643A or 644A (depending on high or low sensor signal) is the Volvo code for your model.
    You could try another camshaft sensor but the fault does not point to that!
  21. The Following User Says Thank You to 960kg For This Useful Post:
  22. #16
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by 960kg View Post
    So what you're saying is this is a garage job. It had a full service including cambelt and waterpump change.
  23. #17
    Trader
    Nov 2010
    chester le street
    969
    sounds expensive what ever it is. how long since had the cambelt done. might be worth getting it checked just incase have a slack belt and its jumped.
  24. #18
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    The belt was done about 3 months ago. It sounds like it maybe the VVT valve from what 960kg's saying, as it only plays up after 4000rpm which is when I'm guessing the cam timing should be changing.
  25. #19
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    If it`s jumped, then this the result.......
    Bent valves..........
  26. #20
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Yeah, I don't think it's jumped, as it runs perfectly below 4000 rpm.
