Hi guys since i did the t5 conversion on the V70 i have not had abs, and therefore no speedo, could it to do with the abs sensors are the newer style found on the later p1s and the ecu does not recognise? I really need help with this one! Is there a way i can get the software taken from the original ecu which is a siemens ecu and put onto the bosch ecu for the abs part? any help is much appreciated thanks
