Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    320mm brakes for 850
    Just read this on VS, looks simple enough.
    http://volvospeed.com/vs_forum/topic...-bbk-by-volvo/
    Modified bracket:
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
    Suspended
    Sep 2011
    Hampshire
    28
    only concern is the welding aspect, i've made my bbk and been looking into making a plate in essence similar that bolts up rather than weld.
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by dalhousie2008 View Post
    When I looked at the bracket, I couldn't see why it needs to be welded one hole used the original mount, and a bolt could be used for the other one.
    PIC][/SIGPIC]
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    As long as the weld has penetrated both parts then it should be as strong enough to take the forces when braking hard.
  5. #5
    Trader
    Aug 2005
    coalville
    68
    There can be problems with differing expansion rates of the cast carrier and bracket cracking the welds.
  6. The Following User Says Thank You to Tim Williams For This Useful Post:
    claymore (Monday 25th June 2012)
  7. #6
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by Tim Williams View Post
    Tim, do you think tha plate would need to be welded on?
    PIC][/SIGPIC]
  8. #7
    Suspended
    Sep 2011
    Hampshire
    28
    TBH not to mention the impacts and vibrations the hubs take. I think i'd take my chances with the unwelded plates or maybe bolt up then safety weld may be a compromise
  9. #8
    Suspended
    Sep 2011
    Hampshire
    28
    i was using the original 280mm t5 calipers and moving further out.
  10. #9
    Suspended
    Sep 2011
    Hampshire
    28
    what calipers is this chap using i assume v50 calipers?
  11. #10
    Suspended
    Sep 2011
    Hampshire
    28
    i used 336mm xc90 discs with 4 pots brembos, and think they will fit under comets.
  12. The Following User Says Thank You to dalhousie2008 For This Useful Post:
    T5RPete (Tuesday 26th June 2012)
  13. #11
    Trader
    Nov 2010
    chester le street
    969
    I rekon i could improve that bracket by making it bolt on. Bracket would be drawn on cad then laser profiled then machined so it can be bolted on. Me personly i wouldnt weld two different materials togrther with out any spec. For all we know it could crack after welding. Beleve me it happens a lot
  14. The Following User Says Thank You to graemewelch For This Useful Post:
    LeeT5 (Wednesday 11th February 2015)
  15. #12
    Trader
    Aug 2005
    coalville
    68
    Looking at it just in the pic it does look like it could be just bolted.
  16. The Following User Says Thank You to Tim Williams For This Useful Post:
    claymore (Tuesday 26th June 2012)
  17. #13
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by graemewelch View Post
    you can put me down for a set then please sir
  18. #14
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by p fandango View Post
    If i can get a hub caliper and disc then no problem. Main problem is i dont have time to go hunting around scrap yards. Or the funds at minute. am sure the hub and disc are easy to get mits on.
  19. The Following User Says Thank You to graemewelch For This Useful Post:
    p fandango (Monday 25th June 2012)
  20. #15
    Trader
    Nov 2010
    chester le street
    969
    have emailed a volvo breaker for a price of calipers and discs. i think the way forward here is to see how many people would be intrested in the brackets.
  21. #16
    Trader
    Nov 2010
    chester le street
    969
    Ive now got some new disc £50 volvo oe and a hub. Just need calipers to make this happen
  22. #17
    martybelfastt5's Avatar
    Jul 2008
    belfast
    760
    mmm at last my car needs decent brakes soo bad
    1995 854 t5r
  23. #18
    T5RPete's Avatar
    Nov 2011
    Hampshire / Shropshire
    303
    How are / did you get on with that?
    Seems as though there a few people who are now looking to do brake upgrades?
  24. #19
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I would certainly be up for a pair of plates.
    PIC][/SIGPIC]
  25. #20
    Jul 2008
    belfast
    760
    me too need brakes bad
    1995 854 t5r
