Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Unhappy Revs not dropping when changing gear
    Hi, I`ve had this problem for a while now and it`s now getting on my nerves. When I change gear the revs "hang" at what they where when I changed gear. The revs drop after about 2-3 seconds if you hold the clutch down. I`ve had this problem on the old engine as well, So I`ve checked for air leaks all ok, cleaned the idle control valve and fitted a new inlet manifold gasket.
    Could it be down to the fact I`m running blue injectors and it`s over fueling ??
    Any ideas ???
    Suspended
    Sep 2011
    Hampshire
    28
    Blues fuel the same as white on the same pressure.
    It does sound like an air leak or such
    Suspended
    Sep 2011
    Hampshire
    28
    You can try my ecu again to rule that out if you like later.
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by dalhousie2008 View Post
    It does it with the RICA 304 and the HLM 304 so I dont think it`s an ECU problem.
  5. #5
    Cookie Monster
    its getting there
    theflyingbrick's Avatar
    Jun 2011
    east london
    1,820
    i dont know if its coinsedence but mine used to that and got it worse and worse to point when i shut off the car would accelerate randomly,trust me its a scary thing when your slowing for traffic!!! anyway i done the usual icv,pipe work,and checking for leaks but it turns out it was the clutch!! i cant explain how or why but i had a new clutch fitted and it stopped??? it needed a new one anyway so i had it done and when i did hey presto.
    full respray..plenty of body mods..comets..ray cat back noise pipe..decat and wrapped downpipe..me7 exhaust manifold..3" throttle body with ported inlet manifold..blue injectors..adjustable fuel reg..reverse intercooler pipework..19t..open cone air filter..255 fuel pump..m-r-p short shift..boost gauge..unknown remap..adjustable suspension..lightweight crank pulley..n/a cams..stripped out interior..and a heavy right foot
  6. #6
    deathrider311271's Avatar
    Apr 2011
    Grimsby
    483
    have you cleaned your throttle body?
    P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
    Previous: 2004 XC90 T6, 240GLT Estate, 343DL
    Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
  7. #7
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by deathrider311271 View Post
    The TB was cleaned when it was fitted.
  8. #8
    Aug 2011
    Glenboig. (scotland)
    2
    im sure i read somewhere that the manual ecu is supposed to hold the rev's between gear changes to help smooth gear change's and if you put an auto ecu in a manual the rev drop as soon at you let off the pedal.
  9. #9
    t5 stealth's Avatar
    Oct 2005
    brighton
    462
    sounds like air leak,
    the pipe under the inlet manifold,on the left as you look at it,tucked between the stat and manifold,
    T5 STEALTH
    http://www.vpcuk.org/forums/album.php?albumid=21 AND A MERCURY CAPRI
    RIP alan (kyebosh)
  10. #10
    This status has no user
    cherry1809's Avatar
    Jul 2008
    Miles from anyone
    1,816
    Mine used to do that. I can't pin point what it was though as when I was trying to find my misfire issue I cleaned EVERYTHING with carb cleaner and it stopped it almost. Just does it when cold now.
    Current Chariots...
    Micra K11 'project sh*tbox'
    V70 D5 daily
    1991 Transit Recovery
  11. #11
    42
    Apr 2012
    Right here, right now!
    76
    Mine does the same, hangs at revs for a couple of seconds before dropping. Volvo told me to clean the throttle, sticky throttle. Not so sure though.
    There's only one Wally Dog....
  12. #12
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by Wally Dog View Post
    When I fitted my 3 inch TB it was cleaned, opened and shut ok. still trying to find what the problem is.
  13. #13
    james's Avatar
    Oct 2008
    sheffield,south yorkshire
    202
    i've had this for a while and it turned out to be the large pcv pipe had split/snapped inside of the protective padding @ the pct endrendering it vertually impossible to find. good old gaffer tape is keeping it going i have a new pcv system and 3" throttle body to fit am waiting to do at same time when i can figure out how i'm going to route the icv. hope this helps
  14. #14
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Just unplug the idle controle valve
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  15. #15
    Volvo sucks....... lots of air
    glock19's Avatar
    Feb 2005
    8
    Quote Originally Posted by claymore View Post
    U Serious ?
  16. #16
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by glock19 View Post
    U Serious ?
    Yep, the ecu will learn within about 20 miles
    PIC][/SIGPIC]
  17. #17
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    How can you tell if the idle control valve is faulty ?
  18. #18
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    'cos your revs hang for a while when you change gear
    Sorry mate, I couldn't help myself
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  19. The Following 3 Users Say Thank You to M-R-P For This Useful Post:
    cherry1809 (Tuesday 26th June 2012),craigoodwood (Thursday 2nd August 2012),Harvey (Wednesday 4th July 2012)
  20. #19
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by martinrpeachey View Post
    hahahahaha
  21. The Following User Says Thank You to oblark For This Useful Post:
    M-R-P (Tuesday 26th June 2012)
  22. #20
    Cookie Monster
    its getting there
    Jun 2011
    east london
    1,820
    take off the idle control valve and shake it you should hear similar to an aerosol can with the ball inside!! if its not rattling then unleash a can of carb spray into the little §§§§§§ and shake it again you should hear the free moving donk donk donk donk if not keep doing it,and if all that fails then replace with new lol hope this helps mate...ignore my clutch comment that was completely different problem lmao i was having a blonde moment when i posted that!!!
  23. The Following User Says Thank You to theflyingbrick For This Useful Post:
    Wally Dog (Thursday 28th June 2012)
