Hello everyone,I don't have a handbook for my 850t5r,can anyone tell me what is the light next to the service light? It's orange with a green triangle.Cheers.Jim.
Thanks. Oh dear,it 's just come on,on the m1,after taking my daughter on a tour of her university.Sounds serious,is it?
Thought that was the lambda light, could be one of many things. Get your codes read before you replace anything though.
Not too serious, could be anything from knock sensor to boost pressure to TPS.
This may help you in other ways http://new.volvocars.com/ownersdocs/...94850_1_1.html
It means the ecu developed a problem, you just need to get the fault code red.
Cheers lads.
Where can I get it read.I've never had to do it before.
The problem is,I'm a born worrier.Would like to sort it.
if a light is on it means trouble..................after all it is a volvo............
"dare to be different"
I didn't notice any difference in performance.But as you say Steve it must be something.
Any recommendations? I am in Sth London.
what year is car
1996.
jim cox (Saturday 16th June 2012)
its a volvo, if a light aint on, it means the bulb's gone.
lol.
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
sounds like lambda light,
it may just have an air leak,that will put that light on,
check all the vac pipes that you can see,inc the one on the end of the inlet manifold (left) as you look as engine,between stat housing and manifold is a small gap you can see into,theres a small elbow hose,this splits and causes probs,
Update.Disconnected battery overnight,light now off.Weird.
